Hi,
i’ve installed serveral times garuda, but this time i got issues with the audio :
link to the image : link
it’s in french but it says that no audio output is detected.
the install is running on a xps 15 9560 (portable computer)
here are my specs :
Kernel: 6.9.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: tsc
root=UUID=caaef372-a1d6-4288-8848-d885e99120c7 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0 wm: kwin_wayland vt: 1
Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 05FFDN v: A00 serial: <superuser required> part-nu: 07BE
uuid: <superuser required> UEFI: Dell v: 1.24.0 date: 08/10/2021
ID-1: BAT0 charge: 42.2 Wh (44.7%) condition: 94.4/97.4 Wh (96.9%) volts: 11.2 min: 11.6
model: LGC-LGC8.33 DELL 5XJ2869 type: Li-ion serial: <filter> status: discharging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF8
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1475 high: 1701 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 1701 2: 1700 3: 800 4: 1700 5: 1700 6: 1700 7: 1700 8: 800
bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 0000:00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 550.90.07
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 bus-ID: 0000:01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-12:4 chip-ID: 0c45:6713 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: iris x11:
drv: iris inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2) device-ID: 8086:591b
memory: 15.23 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: Intel HD Graphics 630
(KBL GT2) driver: mesa intel v: 24.1.1-arch1.1 device-ID: 8086:591b surfaces: xcb,xlib,wayland
device: 1 type: discrete-gpu name: NVIDIA GeForce GTX 1050 driver: nvidia v: 550.90.07
device-ID: 10de:1c8d surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_soc_avs v: kernel
alternate: snd_hda_intel bus-ID: 0000:00:1f.3 chip-ID: 8086:a171 class-ID: 0403
API: ALSA v: k6.9.4-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi v: kernel
bus-ID: 0000:02:00.0 chip-ID: 8086:2526 class-ID: 0280
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0025 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
discoverable: no pairing: no class-ID: 6c010c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: intel_nvme_remap v: N/A
port: f060 bus-ID: 0000:00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 16.56 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B tech: SSD serial: <filter> fw-rev: 2B2QEXE7
temp: 34.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 16.56 GiB (1.8%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 16.56 GiB (1.8%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 16.56 GiB (1.8%) fs: btrfs
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 16.56 GiB (1.8%) fs: btrfs
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 52.0 C pch: 43.5 C mobo: 42.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 32 GiB available: 31.2 GiB used: 5.18 GiB (16.6%)
Processes: 306 Power: uptime: 17m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.44 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 1972 libs: 578 tools: octopi,paru Compilers: clang: 17.0.6
gcc: 14.1.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
System install date: 2024-06-15
Last full system update: 2024-06-15 ↻
i tried with pavucontrol and the only thing that exits is a dummy output.
Thanks for your help !
