KDE says sound is playing but I hear nothing. There's a clear issue with pipewire. I've seen forum posts on the arch forums mentioning this issue but nobody has any clear answers.
╭─[email protected] in ~ took 10s
╰─λ pipewire
[E][02905.331442] mod.protocol-native | [module-protocol-: 708 lock_socket()] server 0x555c31f322a0: unable to lock lockfile '/run/user/1000/pipewire-0.lock': Resource temporarily unavailable (maybe another daemon is running)
[E][02905.331522] pw.conf | [ conf.c: 560 load_module()] 0x555c31f180b0: could not load mandatory module "libpipewire-module-protocol-native": Resource temporarily unavailable
[E][02905.331568] default | [ pipewire.c: 125 main()] failed to create context: Resource temporarily unavailable
╭─[email protected]osh in ~ took 4ms
[🔴] × systemctl status --user pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Wed 2022-06-01 13:07:04 CDT; 54min ago
TriggeredBy: ● pipewire.socket
Main PID: 2959 (pipewire)
Tasks: 2 (limit: 38350)
Memory: 23.3M
CPU: 1.608s
CGroup: /user.slice/user-1000.slice/[email protected]/session.slice/pipewire.service
└─2959 /usr/bin/pipewire
Jun 01 13:07:04 josh-pc systemd[2463]: Started PipeWire Multimedia Service.
╭─[email protected] in ~ took 5ms
╰─λ garuda-inxi
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=2be657fe-74e9-4620-8025-fbda60febab1 rw [email protected]
Mobo: ASUSTeK model: ROG STRIX B460-H GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1601
date: 11/27/2020
Info: model: Intel Core i5-10600K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4317 high: 4500 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 4342 2: 4500 3: 3350
4: 4096 5: 4500 6: 4500 7: 4500 8: 4042 9: 4477 10: 4500 11: 4500
12: 4500 bogomips: 98397
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 7040x1534 s-dpi: 96 s-size: 1862x405mm (73.31x15.94")
s-diag: 1906mm (75.02")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,top-right
model: Dell S3219D serial: <filter> built: 2018 res: 2560x1440 hz: 60
dpi: 92 gamma: 1.2 size: 708x399mm (27.87x15.71") diag: 813mm (32")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: bottom-l model: Dell S3219D
serial: <filter> built: 2018 res: 2560x1440 hz: 60 dpi: 92 gamma: 1.2
size: 708x399mm (27.87x15.71") diag: 813mm (32") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-c model: VG278
serial: <filter> built: 2021 res: 1920x1080 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 13.0.1 DRM
3.46 5.18.1-zen1-1-zen)
v: 4.6 Mesa 22.1.0 direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: SteelSeries ApS Arctis 5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:3 chip-ID: 1038:12aa
Device-4: JMTek LLC. LCS USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:6 chip-ID: 0c76:2018
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Hardware-1: Intel Device driver: ahci v: 3.0 port: 4020 bus-ID: 00:17.0
chip-ID: 8086:a386 rev: class-ID: 0104
Local Storage: total: 2.96 TiB used: 783.39 GiB (25.8%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
type: SSD serial: <filter> rev: 5B0Q scheme: GPT
model: WD10EURX-63C57Y0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 0741 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1022 scheme: GPT
used: 26.64 GiB (2.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 4.5 MiB (0.0%)
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 56.0 C
Processes: 345 Uptime: 56m wakeups: 0 Memory: 31.26 GiB
used: 5.75 GiB (18.4%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1798 lib: 512 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-06-01
Last full system update: 2022-06-01 ↻
