Dear Good people,
I have installed the latest Plasma 6 build Bird of Pray few days ago, and ever since my sound keeps disappearing.
What I mean by that, it is working, I am playing YouTube videos, watching movies etc. and at some point the audio profile(Pro Audio) in the Sound system settings is gone.
To make it work again, I have to switch to another output(digital surround 5.1(IEC958/AC3)) from the available to the right from the drop down menu, and then switch back to Pro audio and everything is working fine again for some time.
The multimedia controls are not working as well and to make that work, I have to restart the system.
Also, my audio system is connected via optical cable to the build in audio card.
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e14ffd94-8207-459f-bdcf-87df18d1ec64 rw rootflags=subvol=@
quiet resume=UUID=69d546da-8dae-4cd8-9cfa-ddbea53b601a loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: Z170X-Gaming 7 v: N/A
Mobo: Gigabyte model: Z170X-Gaming 7 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F21 date: 03/06/2017
Device-1: hidpp_battery_8 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 100% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_9 model: Logitech K350 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
8: 800 bogomips: 63999
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech BRIO 4K Stream Edition
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:3 chip-ID: 046d:086b
gpu: amdgpu d-rect: 5888x2232 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-3: DP-3 pos: top-center res: 2048x1152 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5600 XT (radeonsi
navi10 LLVM 17.0.6 DRM 3.57 6.8.9-zen1-1-zen) device-ID: 1002:731f
memory: 5.86 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5600 XT (RADV NAVI10) driver: mesa radv v: 24.0.6-arch1.2
device-ID: 1002:731f surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
Device-3: C-Media TONOR TC-777 Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0d8c:0134 class-ID: 0300
Device-4: Logitech BRIO 4K Stream Edition
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000
bus-ID: 09:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.39 TiB used: 339.11 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-65L5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R031 scheme: GPT
ID-1: / raw-size: 471.62 GiB size: 471.62 GiB (100.00%)
used: 267.11 GiB (56.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 471.62 GiB size: 471.62 GiB (100.00%)
ID-4: /var/log raw-size: 471.62 GiB size: 471.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 471.62 GiB size: 471.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 1.34 GiB (8.6%)
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 34.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 798
Memory: total: 16 GiB available: 15.57 GiB used: 6.97 GiB (44.8%)
Processes: 302 Power: uptime: 1d 15h 26m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.22 GiB services: org_kde_powerdevil,
Packages: 1917 pm: pacman pkgs: 1907 libs: 567 tools: octopi,paru,yay
pm: snap pkgs: 10 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-05-02
Last full system update: 2024-05-04 ā»
Anyone ever experienced something similar? Any tips appreciated!
Thank you
K.
