Hello Garuda helpers,
Since one of the updates I'm left with a sever sound issue.
At first I noticed no sound was playing and applications such as browser stalls video playback as if waiting for something.
Later I found a weird workaround,
I open the audio settings, and perform a TEST , which seems to reset/release audio buffers of some kind and then sound plays, not only from the test ("front right") but also the browser gets unstuck and continues as normal. same goes for games.
And I have to repeat this any time a sound playing has finished (video in browser or starting another game).
The best hint that I found was perhaps pulseaudio and pipewire have a conflict.
So I went to Garuda-Assistant -> System components and tried to uncheck/remove pipewire support and check/install pulseaudio. However, it stucks at 0% :
resolving dependencies...
:: pulseaudio and pipewire-pulse are in conflict. Remove pipewire-pulse? [y/N] y
Packages (10) pipewire-pulse-1:0.3.60-3 [removal] pulseaudio-16.1-3 pulseaudio-alsa-1:1.2.7.1-1
pulseaudio-equalizer-16.1-3 pulseaudio-jack-16.1-3 pulseaudio-lirc-16.1-3
pulseaudio-rtp-16.1-3 pulseaudio-zeroconf-16.1-3 pulseaudio-bluetooth-16.1-3
pulseaudio-support-1-9
Total Download Size: 1,43 MiB
Total Installed Size: 6,68 MiB
Net Upgrade Size: 6,25 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
pulseaudio-16.1-3-x86_64
pulseaudio-bluetooth-16.1-3-x86_64 0,0 B 0,00 B/s 00:00 [c o o o o o o o o o o o ] 0%
pulseaudio-rtp-16.1-3-x86_64 0,0 B 0,00 B/s 00:00 [c o o o o o o o o o o o ] 0%
pulseaudio-equalizer-16.1-3-x86_64 0,0 B 0,00 B/s 00:00 [c o o o o o o o o o o o ] 0%
pulseaudio-zeroconf-16.1-3-x86_64 0,0 B 0,00 B/s 00:00 [c o o o o o o o o o o o ] 0%
Total (0/9) 0,0 B 0,00 B/s 00:00 [c o o o o o o o o o o o ]
So what do you do now? Am I even on the right path about this problem?
Thank you very much for any help.
Michael
I'm also using the lts-kernel instead of zen-kernel for nvidia related issues. But I think the audio problem was even before that. And it should be independent.
╰─λ garuda-inxi
Kernel: 5.15.79-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=af9e0d6f-f9f5-4dff-9429-ccb173eea0f2 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 2802
date: 10/21/2020
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3542 high: 3594 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3593 2: 3590
3: 3593 4: 3594 5: 3592 6: 3527 7: 3564 8: 3124 9: 3572 10: 3579 11: 3591
12: 3590 bogomips: 88641
prctl and seccomp
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Hewlett-Packard
driver: nvidia v: 470.141.03 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 07:00.0 chip-ID: 10de:1e82 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-4 res: 1920x1080 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.141.03 renderer: NVIDIA GeForce RTX
2080/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Hewlett-Packard
bus-ID: 07:00.1 chip-ID: 10de:10f8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.15.79-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
Local Storage: total: 2.71 TiB used: 64.76 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 37R5 scheme: MBR
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra II 240GB
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 1B6Q
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 64.76 GiB (29.0%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
System Temperatures: cpu: 50.5 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 304 Uptime: 18m wakeups: 1 Memory: 31.26 GiB
used: 4.05 GiB (13.0%) Init: systemd v: 252 default: graphical
pkgs: 2134 libs: 574 tools: gnome-software,octopi,pamac,paru,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-06-07
Last full system update: 2022-11-23
Failed units: dev-binderfs.mount bluetooth-autoconnect.service systemd-networkd-wait-online.service
