Greetings. I am unsure where to post this exactly. So apologies if this is the incorrect place.
I have installed Garuda with the XFCE environment recently on this Vaio VPCSB25FB and after some minor keyring updating I got everything updated and up and running.
One thing I did notice however is that the Stamina/Speed soft-switch does not seem to do anything (Supposedly it switches between Intel iGPU and the discrete Radeon GPU for battery saving purposes). The BIOS provides no option to enable/disable one or the other.
I checked Garuda Settings Manager > Hardware Configuration and both GPUs were detected and had drivers, garuda-inxi also reports both GPUs properly. However Steam only reports the Intel iGPU and reports âTwo Logical GPUsâ.
I was curious to know if there was a way to get the switch working the way it was intended again, instead of relying on the prime method listed there. Or if any other Vaio users found a workaround of some kind. I have seen a few topics in the Arch and Ubunutu forums about it, but they are targeted at other models of Vaio with a similar (but not identical) system.
Thanks, and sorry for the long winded ramble like post.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what youâve tried
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the âhide detailsâ feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Thank you. I will be taking a look at PRIME today after work and see how it does.
The main thing I was wondering however, is if there was a known way to re enable the physical switch, or if it was one of those things sadly locked behind Windows only drivers from Sony.
It does indeed have that directory and file. However the contents of gfx_switch_status dont seem to correlate with the physical state of the switch. (IE the switch is set to speed, and the file says stamina at the moment. And it has been like that after reboot as well.)
I have seen that post in the Arch forum, but since it was repeatedly stated that help should not be looked there for Garuda, I glazed over it.
So, look at PRIME, and investigate this post further is going to my to-do list for today. Thank you for looking into it.
Prime is now set and functioning correctly. So, at least I have that functionality on specific applications. Thank you for suggesting that one.
I have also fiddled around with the files in /sys/devices/platform/sony-laptop and will be making a few scripts to get keyboard backlight control back and a few other things on the side that Vaio Center did in Win7. Should be good for practice.
The quest for re-enabling the physical switch continues however. If no new ideas pop up, Iâll let the thread auto-lock and maybe ask in 6 months again in case anyone figures out something similar before I do (if that is not against the rules).
Unfortunately, I think this problem (HW switch) is definitely out of Garudaâs reach (unless there is a user with the same or similar model as yours, but I donât think so, searching in in the forum).
In my opinion, the only way forward is to search the internet.
At a quick search, at least a couple of threads in other forums said that the HW switch doesnât work at all linux and used equivalents of âourâ prime for their distros. Eg. https://forums.linuxmint.com/viewtopic.php?p=2411103&sid=8dc4066f770c94fe1b7793368841b5bf#p2411103
Or you could work on something (maybe!) similar, like:
The ACPI script is definitely going to get tried after work, thatâs for sure. At least it would give me an example to see how the scripts are written and make some variants for practice.
As for HDMI out, I would have to test it on this model to see if it behaves the same. It is not essential for my purposes, but investigating it and finding a possible workaround (if there is an issue with this model at all), would a nice thing to have. You never know when your boss randomly wants something hooked up to the projector at the last minute and you are the only one with a laptop in the room.
Anyway, you have been of great help, and gave me something to keep me busy for a while. I will mark it as solved and make another thread if I have more specific questions later.
