Sometimes when I turn on my Laptop there is no any wifi Icon So I have to restart my laptop to see wifi Icon on top bar. Also Sometime I can not connect to a wifi network untill I restart my laptop does not matter 5Ghz or 2.4.
Also Hotspot icon disappers when I connect to a wifi network does not matter if 2.4 or 5Ghz.
A really very humble request can you include pathces for Intel Wireless cards in Garuda Assistant or settings? like turning on 5Ghz Hotspot. I know it is upstream kernel issue. But As a complete OS there should be some toogles for pathces in Garuda settings manager.
inxi -Faz:
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=05db8d2f-5bd0-41a5-b385-6b703c16571d rw rootflags=subvol=@
resume=UUID=1da77a3c-4a0a-44ca-b58d-9c8ec4a1622a loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: Dell product: Latitude E6440 v: 00
Mobo: Dell model: 0159N7 v: A00 serial: <superuser required> UEFI: Dell
v: A24 date: 06/13/2019
ID-1: BAT0 charge: 39.1 Wh (100.0%) condition: 39.1/62.2 Wh (62.9%)
volts: 12.6 min: 11.1 model: Sanyo DELL NH6K941 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-4200M bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1607 high: 2492 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 2492 3: 800
4: 2337 bogomips: 19954
vulnerable
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 0c45:649d class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x313c built: 2011 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:088e
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 2-1.5:3 chip-ID: 8087:07da class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Local Storage: total: 238.47 GiB used: 140.77 GiB (59.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7SB6S-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1006 scheme: GPT
ID-1: / raw-size: 221.09 GiB size: 221.09 GiB (100.00%)
used: 140.77 GiB (63.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 221.09 GiB size: 221.09 GiB (100.00%)
ID-4: /var/log raw-size: 221.09 GiB size: 221.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.09 GiB size: 221.09 GiB (100.00%)
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C mobo: 49.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2555
Processes: 235 Uptime: 5h 7m wakeups: 4 Memory: 15.53 GiB
used: 3.56 GiB (22.9%) Init: systemd v: 252 default: graphical
pkgs: 1302 libs: 325 tools: octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
afzl-wtu:
inxi -Faz
Please post garuda-inxi
, not inxi -Faz
I thought to check whether you are dual-booting Windows or not (Windows is able to hold on to the network card while hibernating or in the quick boot “shutdown” state), but inxi -Faz
does not show this.
Is patching the Linux kernel a “humble” request?
It’s probably best to fix issues with the kernel at the kernel development level, not the OS level. If you would like to be helpful, submit a bug report for your issue: Reporting bugs — The Linux Kernel documentation
I never dual boot linux and windows, I only use Garuda Linux. By the way Template asked me to post out put of inxi -FaZ here but anyway:
Output of sudo garuda-inxi:
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E6440 v: 00 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0159N7 v: A00 serial: <filter> UEFI: Dell v: A24
date: 06/13/2019
volts: 12.5 min: 11.1 model: Sanyo DELL NH6K941 type: Li-ion
Info: model: Intel Core i5-4200M socket: rPGA988B bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Speed (MHz): avg: 1641 high: 2495 min/max: 800/3100 base/boost: 2500/2500
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 100 MHz cores: 1: 2203 2: 1070 3: 2495 4: 799 bogomips: 19954
vulnerable
IF-ID-1: wireguard state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 238.47 GiB used: 141.03 GiB (59.1%)
family: Marvell based SSDs size: 238.47 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1006 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 234d 22h cycles: 6505
used: 141.03 GiB (63.8%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
System Temperatures: cpu: 62.0 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2066
Processes: 253 Uptime: 12h 42m wakeups: 3 Memory: 15.53 GiB
used: 4.2 GiB (27.0%) Init: systemd v: 252 default: graphical
pkgs: 1302 libs: 325 tools: octopi,pamac,paru Shell: garuda-inxi (sudo)
Garuda (2.6.9-1):
System install date: 2022-10-30
Last full system update: 2022-11-12
Is partially upgraded: Yes
Failed units: mnt-data.mount
A partially upgraded state can be a source of major problems. Are you having issues updating?
garuda-update
Paste the input/output into the thread if you encounter any error messages.
@afzl-wtu I have a laptop with similar symptoms. The only conclusion that I was able to come up with for my current use case is that the wireless NIC that is on my laptop is not fully supported by Linux. It is not an issue with the OS.
I have a wireless NIC that is CnVio v1 key E, and model is an intel 9560NGW. Perhaps it may be a compatibility issue with Linux?
tag
1 December 2022 10:15
9
Dont. Change.Anything.
I have just set-up a laptop with garuda for the first time, before only with PC, and 100% this is a bug for laptops.
If you power on with the ethernet connected it works , but if you then disconnect and move , sometimes you will not see any wifi OR Bluetooth connections - to fix I have to power down , re-connect the ethernet and reboot - and hey presto wifi and bluetooth return.
Seems like the eth0 and wifi are fighting over address space or something?
