Someone with this problem?
someone with this problem?
have it since yesterday
/usr/lib/firmware/amd-ucode/README.zst exists in both 'amd-ucode' and 'linux-firmware-git'
/usr/lib/firmware/amd-ucode/microcode_amd.bin exists in both 'amd-ucode' and 'linux-firmware-git'
/usr/lib/firmware/amd-ucode/microcode_amd_fam15h.bin exists in both 'amd-ucode' and 'linux-firmware-git'
/usr/lib/firmware/amd-ucode/microcode_amd_fam16h.bin exists in both 'amd-ucode' and 'linux-firmware-git'
/usr/lib/firmware/amd-ucode/microcode_amd_fam17h.bin exists in both 'amd-ucode' and 'linux-firmware-git'
/usr/lib/firmware/amd-ucode/microcode_amd_fam19h.bin exists in both 'amd-ucode' and 'linux-firmware-git'
i see these updates:
chaotic-aur/linux-firmware-git          20240130.001ba06d-1       20240201.36777504-1         1.12 MiB
core/linux-firmware-whence              20240115.9b6d0b08-1       20240115.9b6d0b08-2         0.00 MiB
core/amd-ucode                          20240115.9b6d0b08-1       20240115.9b6d0b08-2         0.07 MiB
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
garuda-inxi really needed for packaging conflicts?
okay!
in the time between OP I just updated linux-firmware-git to see if it still conflicts but it’s still
I did not intall those two packages manually as far as I recall
I could just remove amd-ucore but I would be interested if there is some general problem.
in linux-firmware git log there were some amd related commits
Kernel: 6.7.2-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=ffafe519-aac6-4ad6-bc3a-dc6c9e631b4d rw rootflags=subvol=@
quiet resume=UUID=9c5bba6f-90c1-4259-bca0-11877dc5ff07 loglevel=3
mitigations=off sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1
threadirqs ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: X370 GAMING PRO CARBON (MS-7A32)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.Q1
date: 05/19/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3630 high: 4136 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3586 2: 3561
3: 3436 4: 3589 5: 3568 6: 3591 7: 3550 8: 3560 9: 3605 10: 3562 11: 3560
12: 3943 13: 4136 14: 3741 15: 3521 16: 3577 bogomips: 108843
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: XFX
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 29:00.0 chip-ID: 1002:73bf
Device-2: Logitech StreamCam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2:2 chip-ID: 046d:0893
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
gpu: amdgpu d-rect: 4480x2640 display-ID: 0
Monitor-1: DP-2 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1200 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd v: N/A glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21 LLVM
16.0.6 DRM 3.56 6.7.2-AMD-znver3) device-ID: 1002:73bf memory: 15.62 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: mesa radv
v: 24.1.0-devel (git-16f6f50ce4) device-ID: 1002:73bf
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: AMD Radeon RX 6800 driver: amd v: (AMD proprietary shader compiler)
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 2 type: cpu
name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-devel
(git-16f6f50ce4) (LLVM 16.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 29:00.1 chip-ID: 1002:ab28
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: M-Audio Oxygen Pro Mini driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:2 chip-ID: 0763:103b
class-ID: 0103 serial: <filter>
Device-4: Logitech StreamCam
Device-5: Focusrite-Novation Scarlett 2i2 4th Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 1235:8219 class-ID: 0102 serial: <filter>
Device-6: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.7.2-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 21:00.0
IF-ID-1: br-df6dff0c394c state: down mac: <filter>
Local Storage: total: 6.37 TiB used: 1.2 TiB (18.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra II 500GB
tech: SSD serial: <filter> fw-rev: 10WD scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 2T00
tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM006-2DM164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.2 TiB (68.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 1.2 TiB (68.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
maj-min: 259:2
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 68.99 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 62.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 52.0 C
Processes: 547 Uptime: 31m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.73 GiB used: 15.78 GiB (25.2%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2444 libs: 619 tools: octopi,paru pm: appimage
pkgs: 0 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-11-29
Last full system update: 2024-02-01
Is partially upgraded:   Yes
Just wrong place to ask.
Maybe you can post full log?
i now removed the package to finish my other updates I needed
I think this is not a problem, question is just if amd-ucode is basically replaced and there would need to be a conflict entry on the package
like I said, I do not recall manually installing amd-ucode or linux-firmware-git
now it’s down to this
╰─λ sudo pacman -S amd-ucode
[sudo] password for z3n:
resolving dependencies...
Package (1)     New Version          Net Change
core/amd-ucode  20240115.9b6d0b08-2    0,16 MiB
Total Installed Size:  0,16 MiB
(1/1) checking keys in keyring        [----------------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity        [----------------------------------------------------------------------------------------------] 100%
(1/1) loading package files        [----------------------------------------------------------------------------------------------] 100%
(1/1) checking for file conflicts        [----------------------------------------------------------------------------------------------] 100%
amd-ucode: /usr/lib/firmware/amd-ucode/README.zst exists in filesystem (owned by linux-firmware-git)
amd-ucode: /usr/lib/firmware/amd-ucode/microcode_amd.bin exists in filesystem (owned by linux-firmware-git)
amd-ucode: /usr/lib/firmware/amd-ucode/microcode_amd_fam15h.bin exists in filesystem (owned by linux-firmware-git)
amd-ucode: /usr/lib/firmware/amd-ucode/microcode_amd_fam16h.bin exists in filesystem (owned by linux-firmware-git)
amd-ucode: /usr/lib/firmware/amd-ucode/microcode_amd_fam17h.bin exists in filesystem (owned by linux-firmware-git)
amd-ucode: /usr/lib/firmware/amd-ucode/microcode_amd_fam19h.bin exists in filesystem (owned by linux-firmware-git)
garuda-update -- --overwrite '*'
Brute force :wink:
Try switching to linux-firware instead of the git version.
