I have reinstall the KDE dragonized plasma with last release plasma 6 ISO ..
i found some theming issue..
themeing not applied to root mode : when i open dolphin as root, or in case of garuda apps like (garuda network assistent, garuda boot options, ) .. it uses breeze-light or maybe oxygen light theme.
garuda apps are not match kavantum theme : the garuda welcome apps or garuda assistent .. they seems to be using oxygen theme ..not kvantum theme ..
i also changed the kvantum theme ..not works ..
trying to copy /etc/skel/ to / .. still not work …
╰─λ garuda-inxi
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b15106c4-d6fc-4f10-9f9e-12d2b1293736 rw rootflags=subvol=@
quiet resume=UUID=46d434b4-5a6a-4b78-8be1-c8e05a25cbb4 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: Gigabyte product: B450M K v: -CF
Mobo: Gigabyte model: B450M K-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FDd
date: 09/02/2024
Info: model: AMD Ryzen 5 4600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 400 min/max: 400/4308 scaling: driver: amd-pstate-epp
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 88635
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
active: DP-1 empty: HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 40.0 C
Monitor-1: DP-1 res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.10.10-zen1-1-zen) device-ID: 1002:1636
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.3-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.58 TiB used: 61.25 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500413AS
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC4B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240BX500SSD1
tech: SSD serial: <filter> fw-rev: 056 scheme: GPT
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 33.52 GiB (33.5%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/sdb4 maj-min: 8:20
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 27.73 GiB (27.7%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 33.52 GiB (33.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 4.03 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 45.9 C mobo: 37.0 C gpu: amdgpu temp: 39.0 C
Memory: total: 16 GiB note: est. available: 15 GiB used: 4.4 GiB (29.3%)
Processes: 349 Power: uptime: 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1612 libs: 437 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-09-19
Last full system update: 2024-09-30
