SGS
1
Some tester needed
Check yours, mine is de, de. Backup your .config/hypr/hyprland.conf
file.
localectl
System Locale: LANG=en_GB.UTF-8
VC Keymap: uk
X11 Layout: gb
Run the script
#!/bin/bash
# .local/bin/garuda-locale.sh
localectl > /tmp/garuda-locale.txt
cat /tmp/garuda-locale.txt | grep Keymap > /tmp/keymap.txt
cat /tmp/garuda-locale.txt | grep Layout > /tmp/layout.txt
locale=$(cat /tmp/keymap.txt | awk '{ print $3 }')
variant=$(cat /tmp/layout.txt | awk '{ print $3 }')
sed -i "/kb_layout =/c\kb_layout = $locale" .config/hypr/hyprland.conf
sed -i "/kb_variant =/c\kb_variant = $variant" .config/hypr/hyprland.conf
and check if .config/hypr/hyprland.conf
use the correct values and login works fine.
Use live ISO if not
@bryambalan missing your MR
, but I can’t test it and IDK which check failed in Gitlab.
@korobert maybe you can test this script
veitw
2
Hyprland just wouldn’t like ‘us’ in kb_variant, get a big red bar on top with a warning
localectl
System Locale: LANG=en_CA.UTF-8
VC Keymap: us
X11 Layout: us
Sure. I just tried it now but still not good.
After the script
localectl output:
localectl
VC Keymap: uk
X11 Layout: gb
and hyprland.conf
input {
kb_layout = uk
kb_variant = gb
kb_model =
kb_options =
kb_rules =
numlock_by_default= true
follow_mouse = 1
So after scritp i got an extra line in the hyprland.conf
kb_variant = gb
this was not there before.
But this line
kb_layout = uk
is still “uk”
This sould be “gb” in my case for working good.
SGS
5
Invaild keyboard layout passed. ( rules: , model: , variant: , options: , layoyt: uk )
Hyprland may not work correctly
Ok, setting the kb_variant break the config.
New test.
#!/bin/bash
sed -i "/kb_layout =/c\kb_layout = $layout" .config/hypr/hyprland.conf
if [ "$variant" != "$layout" ]
then
sed -i "/kb_layout =/c\kb_layout = $variant" .config/hypr/hyprland.conf
fi
I tried this script. It is working fine for me.
localectl doesnt change:
╰─λ localectl
VC Keymap: uk
X11 Layout: gb
and in hyprland.conf is still okay form me.
input {
kb_layout = gb
kb_model =
kb_options =
kb_rules =
follow_mouse = 1
no error, no red bar.
SGS
Closed
7
