I have been trying to install several extensions to code-oss, the arduino package in particular, which includes platformio (experimenting with esp32-cam) and cannot get the extension to enable. The extension indicates "enabled globally", but can't find it and no icon in the toolbar. There a couple other extensions giving similar trouble. I can't find anything about it in this forum or anywhere else, other than some issues with code-oss lacking some extensions. I was sure this would be a known issue, but apparently not. The suggested solution on an Arch forum was to uninstall code-oss and install vsc through pacman. As I am not a MS lover by nature , I'd like to get code-oss working with the extension, if possible.
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6cafe1ae-53e0-4003-8e56-0566259c4051 rw [email protected]
loglevel=3 quiet
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: ASUS product: All Series v: N/A serial: N/A
Mobo: ASUSTeK model: H97M-E v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2702 date: 03/28/2016
Info: model: Intel Core i5-4690 socket: BGA1155 (1150) note: check bits: 64
type: MCP arch: Haswell family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 3492 high: 3493 min/max: 800/3900 base/boost: 3506/3900
scaling: driver: intel_cpufreq governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 3493 2: 3492 3: 3492 4: 3493 bogomips: 27933
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
Device-2: Logitech HD Webcam C615 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2 chip-ID: 046d:082c
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.6x9.3")
s-diag: 484mm (19.1")
Monitor-1: HDMI2 res: 1600x900 hz: 60 dpi: 58
size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.6 compat-v: 3.0 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-3: Logitech HD Webcam C615 type: USB
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.45 running: yes
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 3-10:5 chip-ID: 148f:5572 class-ID: 0000 serial: <filter>
IF: wlp0s20u10 state: up mac: <filter>
Local Storage: total: 4.55 TiB used: 1.81 TiB (39.7%)
model: WD5000AACS-00ZUB0 family: Caviar Green size: 465.76 GiB block-size:
physical: 512 B logical: 512 B sata: 2.5 speed: 3.0 Gb/s type: N/A
serial: <filter> rev: 1B01 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 288d 4h cycles: 9604
model: WD40EFRX-68WT0N0 family: Red size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0A82 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 273d 3h cycles: 137
model: WD5000LPVX-80V0TT0 family: Blue Mobile size: 465.76 GiB block-size:
rpm: 5400 serial: <filter> rev: 1A01 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 235d 9h cycles: 59632
Old-Age: g-sense error rate: 1586
ID-1: / raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.81 TiB (44.1%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
used: 546 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
used: 1.81 TiB (44.1%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 465.5 GiB size: 4.09 TiB (900.43%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 15.32 GiB used: 90.4 MiB (0.6%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 270 Uptime: 4d 14h 37m wakeups: 7 Memory: 15.32 GiB
used: 3.81 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1761 lib: 410 Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-03-08
Last full system update: 2022-02-16
Snapshots: Timeshift
Failed units: smartd.service
