Some errors updating frome some mirror
Hello Garuda users.
today I have some errors updating, so system stop updating
Errors are:
error: failed retrieving file 'lib32-mesa-22.3.2-2-x86_64.pkg.tar.zst' from mirror.metanet.ch : Recv failure: Connection reset by peer
error: failed retrieving file 'lib32-mesa-vdpau-22.3.2-2-x86_64.pkg.tar.zst' from mirror.metanet.ch : Recv failure: Connection reset by peer
error: failed retrieving file 'qt5-webengine-5.15.12-1-x86_64.pkg.tar.zst' from mirror.metanet.ch : Recv failure: Connection reset by peer
warning: too many errors from mirror.metanet.ch, skipping for the remainder of this transaction
error: failed retrieving file 'mesa-22.3.2-3-x86_64.pkg.tar.zst' from mirror.metanet.ch : Recv failure: Connection reset by peer
error: failed retrieving file 'vlc-3.0.18-6-x86_64.pkg.tar.zst' from mirror.metanet.ch : Recv failure: Connection reset by peer
Thanks if someone can solve or help
It looks like that mirror is having some troubles.
How are you updating (it is always a good practice to provide the complete input and ouput from terminal)?
If using garuda-update, this would refresh the mirrorlist and you might have better luck.
If not working, you could temporarily comment that mirror in your /etc/pacman.d/mirrorlist.
Something like this:
#Server = http://mirror.metanet.ch/archlinux/$repo/os/$arch
#Server = https://mirror.metanet.ch/archlinux/$repo/os/$arch
Anyway, checking the mirror status page, it looks like it had only a couple of errors recently, so this could be a temporary problem, and trying later might succeed.
I only update via terminal with UPDATE command, but is not workig due to the mirros issue
Please use the correct spelling, newbies reading along here will thank you. :slight_smile:
update
or
garuda-update
ahh yes, obviously is update not UPDATE
I use update comand and not garuda-update because I'm lazy :joy:
The issue seems resolved, no server problem now
Thanks
