After spending some time trying Fedora, I’ll give Garuda another try. Although several issues in Garuda disappeared in Fedora; I’ve been having other annoying issues: Discover crashing constantly, Dolphin freezing 8 seconds when opening, and occasional visual glitches and freezes. Either the issues are much easier to search and fix because more people are using it and asking about it; or nobody knows and it’s harder without being able to easily switch back to X11, switch kernel, etc. It’s not such a tinkering-free experience. Oh, and I realized how hard it is to have consistent look-and-feel across all Qt and GTK apps!
Anyway. Giving Garuda another try. The biggest deal-breaker was DaVinci not working. If that one could work, I’d be good to go.
I’m on a clean system. No kernel change or special configuration done.
I installed ‘davinci-resolve’ from the AUR.
I open it and it launches right away. Good start.
Problem #1: Global Menu not working with DaVinci on Garuda. In Fedora with Plasma 6, this works perfectly fine. If I remove the global menu, then I get access to the menu. Someone else here was saying that global menu worked for them? What’s the difference? I’m on NVidia with HDMI output.
Problem #2: Inserting the first clip gives the error “GPU memory is full”. In Fedora, I got that error too; but switching to OpenGL mode worked. Fedora has Nouveau drivers by default; after tinkering and ensuring I had RPM drivers installed, CUDA also worked and the GPU error disappeared.
In Garuda, I’m pretty sure I have the right drivers. CUDA mode gives that error. OpenGL mode doesn’t. However, even with OpenGL, I can add the clip, but I’m unable to get any preview of the clip.
The ReadMe file says to install a special NVidia driver; but I really don’t think that’s a good idea.
Here’s my inxi
Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=51ef4a7a-fb89-43c3-a466-7318e0363e7e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.4.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 41.1 Wh (100.0%) condition: 41.1/58.8 Wh (70.0%)
volts: 16.3 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 907 high: 1184 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 800
5: 900 6: 900 7: 800 8: 900 9: 1184 10: 900 11: 900 12: 900
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.3-arch1.1
device-ID: 8086:9bc4 memory: 7.54 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.3-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 555.58.02
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.9.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 1.21 TiB (38.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.26 TiB size: 1.26 TiB (100.00%) used: 268.41 GiB (20.7%)
fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-2: /boot/efi raw-size: 625 MiB size: 623.7 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.26 TiB size: 1.26 TiB (100.00%)
used: 268.41 GiB (20.7%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-4: /var/log raw-size: 1.26 TiB size: 1.26 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.26 TiB size: 1.26 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 12.2 MiB (0.1%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 65.0 C pch: 62.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 5.68 GiB (36.8%)
Processes: 346 Power: uptime: 3h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1584 libs: 447 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-07-17
Last full system update: 2024-07-17
