I opened the terminal and found that Fastfetch wasn’t displayed.
I went into settings apps:xfce4-terminal:preferences [Xfce Docs], checked run a custom command instead of my shell, and pasted in /usr/bin/fastfetch.
I closed the terminal and reopened it only to find the terminal opening for a split second, showing the Fastfetch details, and then closing.
Is there any way of preventing the terminal’s near instantaneous closure, or have I wrecked it?
Kernel: 6.6.14-2-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
root=UUID=f60f6675-0606-42d7-9815-e0fbe7be0409 rw rootflags=subvol=@ quiet
resume=UUID=d807950b-e01b-4ea5-b73f-d50f5ae401e3 loglevel=3 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm v: 4.18.0 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 15.8 Wh (45.8%) condition: 34.5/42.1 Wh (82.0%) power: 12.6 W volts: 11.8
min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 704
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1872 high: 2692 min/max: 400/4056 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 2082 2: 2395 3: 1624 4: 1368 5: 1545 6: 1418 7: 1384 8: 1347
9: 2041 10: 1914 11: 2665 12: 2692 bogomips: 50320
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 39.0 C
Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.11 compositor: xfwm v: 4.18.0 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4161 built: 2020 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080
min: 640x480
API: Vulkan v: 1.3.276 layers: 5 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 23.3.4-arch1.2 device-ID: 1002:164c surfaces: xcb,xlib
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.3.4-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.14-2-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire
-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u2 state: up speed: 150 Mbps duplex: half mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no
pairing: no
Local Storage: total: 476.94 GiB used: 8.02 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
fw-rev: FXV7101Q temp: 32.9 C scheme: GPT
ID-1: / raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 7.35 GiB (4.7%) fs: btrfs
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 312.18 GiB size: 312.18 GiB (100.00%) used: 686.7 MiB (0.2%) fs: btrfs
ID-4: /var/log raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 7.35 GiB (4.7%) fs: btrfs
ID-5: /var/tmp raw-size: 156.25 GiB size: 156.25 GiB (100.00%) used: 7.35 GiB (4.7%) fs: btrfs
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
System Temperatures: cpu: 42.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (rpm): cpu: 0
Processes: 360 Uptime: 18m wakeups: 0 Memory: total: 8 GiB note: est. available: 7.15 GiB
used: 2.61 GiB (36.5%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1268 libs: 394 tools: paru Client: shell wrapper
v: 5.2.26-release inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-29
Last full system update: 2024-02-01
Edit: Problem solved (I hope)
I dug through my system until I came across /home/colin/.config/xfce4/xfconf/xfce-perchannel-xml/
It contained the line /usr/bin/fastfetch so I backed up the file and deleted the offending line.
My terminal now seems to be working OK again - phew ![]()
I won’t be doing that trick again.
