Greetings Wizards of the Garuda Team,
i just installed Garuda and everything is working fine except Wifi. Under "garuda-inxi" i get this:
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac:
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 06:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF-ID-1: enp7s0f3u2u1 state: unknown speed: -1 duplex: half mac:
Seems to be a driver issue. Wifi is enabled in Bios, "rtw89-dkms-git" is installed.
In Garuda Network Assistant it says Wifi is enabled.
Im not a complete Newb when it comes to PCs or Linux, tell me what you need to assist me with my problem.
(Since im new to this board i appreciate if you tell me any errors i made in this post and how i can do it better in the future.)
Thanks in advance,
Magamarc
As you have updated i would reboot
filo
20 April 2022 17:33
#6
Hi there, welcome!
Have you already tried with a different kernel?
linux-zen, linux, etc...
You could also check the suggestions in the last Lenovo legion 5 pro here
https://wiki.archlinux.org/title/Laptop/Lenovo#Legion_series
Realtek RTL8852AE WiFi 6 802.11ax PCIE Adapter requires linux-firmware and rtw89-dkms-git AUR .
No, i will try now and come back later.
Fixed!
Thank you very much im so happy I got this Laptop today, instantly banished Win 11 and now im ready to dive into the magical world that is Garuda and Elden Ring.
What i did:
sudo pacman -S linux
reboot, Grub automatically switched to the new Kernel.
Done!
Again thanks alot <3
filo
20 April 2022 18:43
#9
To avoid problems in the future with other stuff, it's always advisable to install also the headers of the kernel of your choice (linux-headers in this case)
system
closed
22 April 2022 18:43
#10
