Hello
I have a primary 144 hz monitor I use for gaming and a second one that has 75 hz.
Every time I want to use VSync in any game, my fps get stuck at 75 fps instead of 144 fps.
This problem does not occur on Windows 10 while using VSync where the fps remain capped at 144 fps.
Updating graphics drivers did not resolve the problem.
I use KDE Plasma, zen kernel and I'm on Garuda Linux Dragonized.
Please help
Also, give a look at this thread.
This might be a limitation.
There are some workarounds that you could try, anyway.
Hello all,
I have a question about display refresh rates.
I have a Dell 144 hz ultrawide screen with and a 60hz drawing display by xp pen I chose that one specifically because of native support of linux.
My issue starts when both are active, as the refresh rate syncs to the lower one. meaning my 144 hz syncs to 60 hz whereas without the display it works normally and settings for the display do not seem to separate the two.
Is there a possibility to fix this ?
Kernel: 5.16.4-zen1-1-ze…
ajdj:
I’m sorry but I can’t upload it as a screenshot since I’m a new user)
Hallelujah, we don’t like terminal output as images.
Neither from new nor “old” users of the forum.
Look at them, what I’m about to change your post.
I have found a solution for this problem!
Put ~/.config/kwinrc in Konsole
Add MaxFPS=144 to the [Compositing] section.
Restart your computer
Sources:
Hello all,
https://www.reddit.com/r/kde/comments/cwedej/comment/eyaqmnk/?context=3
Thank you filo!
I go to the trouble of formatting it and you can't think of anything better than deleting it?
Why did you delete it?
Because it was not a garuda-inxi?
inxi -Faz?
inxi -Faz
Kernel: 5.18.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=9d68907e-a8b5-412d-bc79-433b049a2425 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: MSI model: B250M PRO-VD (MS-7A74) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/28/2018
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xF0
desc: 1x6 MiB
Speed (MHz): avg: 3263 high: 3440 min/max: 800/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 3440 2: 3419 3: 3280
4: 2915 bogomips: 24000
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
Screen-1: 0 s-res: 3200x1080 s-dpi: 92 s-size: 883x301mm (34.76x11.85")
s-diag: 933mm (36.73")
Monitor-1: DP-4 pos: primary,top-right res: 1920x1080 dpi: 92
Monitor-2: HDMI-0 pos: bottom-l res: 1280x1024 dpi: 86
size: 380x300mm (14.96x11.81") diag: 484mm (19.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
system
Closed
1 June 2022 19:19
8
