Hello
Please advise.
After the last crash, I reinstalled from updated kernel and has been running almost flawlessly for the last 15 days.
Yesterday I left the computer for about 3 hours. When I came back, I could not login.
I restarted and when Garuda opened, the desktop was different, there was no taskbar or dock. I only had some right-click menu.
I restarted again with the same results.
I restarted and used the advanced options and booted with a failsafe option. Same result .
I restarted and went into the snapshots and tried 3 option even going back to the 10th Aug.
Every time I got the same result - no task bar and no dock. The system is still booting quickly but I cannot access programs etc.
I have tried looking in the forums, but cannot find anything similar.
I am currently using a live disk version.
Thanks
System: Kernel: 5.13.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_DR460NIZED_SOARING_ quiet systemd.show_status=1 driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Console: tty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: N/A model: N/A serial: N/A UEFI: American Megatrends v: 5.12
date: 11/10/2018
CPU: Info: Quad Core model: Intel Core i5-8350U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L1: 256 KiB L2: 6 MiB L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 30399
Speed: 3601 MHz min/max: 400/3600 MHz base/boost: 1600/8300 volts: 0.7 V ext-clock: 100 MHz
Core speeds (MHz): 1: 3601 2: 3600 3: 3601 4: 3568 5: 3256 6: 3600 7: 3600 8: 3600
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-6:5
chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Display: server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 70 size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: Intel USB PnP Sound Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-1.2:4 chip-ID: 8086:0808 class-ID: 0300
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-6:5
Sound Server-1: ALSA v: k5.13.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel
port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On driver: ath9k
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 168c:0034 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.1:4
IF: enp0s20f0u1u1 state: down mac: <filter>
Bluetooth: Device-1: Toshiba Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:9
chip-ID: 0930:021c class-ID: e001
Drives: Local Storage: total: 2.97 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Indilinx model: IND-S3MP 256G size: 238.47 GiB block-size:
physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter> rev: B1T2
temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 83d 23h cycles: 761 read: 2.8 MiB
written: 4.7 MiB Pre-Fail: reallocated sector: 100 threshold: 50
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Backup+ SL size: 931.51 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 0143 scheme: MBR
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital model: WD Elements 10B8
drive model: WD20NMVW-11EDZS2 family: Elements / My Passport (USB, AF) size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s type: HDD rpm: 5200
serial: <filter> drive serial: <filter> rev: 1012 drive rev: 01.01A01 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 95d 9h cycles: 2178
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade size: 7.36 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.27 scheme: MBR
ID-1: swap-1 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A
Info: Processes: 217 Uptime: 14m wakeups: 0 Memory: 7.56 GiB used: 4.05 GiB (53.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1157 lib: 290
Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Hello.
Before you open a new help request, read relevant sections of the Arch and Garuda wiki. Thoroughly search your issue and any error messages in the forum and on the web.
Post your terminal in- and output from:
inxi -Faz
