Hi,
Could change the instruction at Installation instructions | Garuda Linux wiki from sha256sum file.iso
to sha256sum -c file.sha256
and remove the instruction cat file.sha256
If using sha256sum -c file.sha256
it will check the iso (if it is in the same dir) and just give OK if all is good.
