Hello community!
Here my first topic on this forum, hope I will respect the rules... If not, tell me what I wrong!
I'm trying to update the system after some weeks but I'm finding some problems.
sudo pacman -Syu
:: Aggiornamento del sistema in corso...
:: Vuoi sostituire hwids con core/hwdata? [S/n]
:: Vuoi sostituire kvantum-qt5 con community/kvantum? [S/n]
risoluzione delle dipendenze in corso...
ricerca dei pacchetti in conflitto in corso...
errore: impossibile eseguire l'operazione richiesta (impossibile soddisfare le dipendenze)
:: l'installazione di expat (2.4.2-1) interrompe la dipendenza 'expat=2.4.1' richiesta da lib32-expat
It's telling me that there's a problem with expat dependencies.
update
core is up to date
extra is up to date
community is up to date
errore: il seguente pacchetto non è stato trovato: garuda-update
Refreshing mirrorlists using reflector, be patient please..
[2022-01-15 16:42:19] WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2022-01-15 16:42:24] WARNING: failed to rate http(s) download (https://archlinux.mailtunnel.eu/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2022-01-15 16:42:30] WARNING: failed to rate http(s) download (https://mirror.cyberbits.eu/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2022-01-15 16:42:37] WARNING: failed to rate http(s) download (https://mirror.chaoticum.net/arch/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2022-01-15 16:42:37] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): <urlopen error [Errno 101] Network is unreachable>
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-01-15 15:42:37 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2022-01-15 15:42:13 UTC
# Last Check: 2022-01-15 15:08:32 UTC
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
Server = https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
:: Sincronizzazione dei database in corso...
core 136,7 KiB 117 KiB/s 00:01 [######################################################################] 100%
extra 1553,8 KiB 114 KiB/s 00:14 [######################################################################] 100%
community 6,0 MiB 84,6 KiB/s 01:13 [######################################################################] 100%
Checking for keyring update before starting full system update..
errore: il seguente pacchetto non è stato trovato: garuda-hotfixes
attenzione: archlinux-keyring-20220114-1 è aggiornato e sarà ignorato
errore: il seguente pacchetto non è stato trovato: chaotic-keyring
It didn't find garuda-update, garuda-hotfixes and chaotic-keyring packages.
If I try to update via pamac it finds problems with dependencies as well:
"impossibile soddisfare le dipendenze:
- removing lib32-expat breaks dependency 'lib32-expat' required by lib32-wayland,
- Se possibile, rimuovi lib32-wayland e riprova"
and it suggests me to remove a lot of lib32* libraries (like lib32-wayland, lib32-opencl-mesa, lib32-libva-mesa-driver, and so on...), but I'm afraid to do it, I don't want break the system.
Could someone help me?
What can I do?
Do you need more details by me?
Thanks a lot to everyone who want help me!
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3387fe52-e8cb-45c6-87fb-f4e8ea30cb2c rw [email protected]
quiet acpi_backlight=vendor
cryptdevice=UUID=551e16bb-03e7-4bf4-83c3-40579df2ea66:luks-551e16bb-03e7-4bf4-83c3-40579df2ea66
root=/dev/mapper/luks-551e16bb-03e7-4bf4-83c3-40579df2ea66 splash
resume=/dev/mapper/luks-fbbf49a3-e58e-445b-a8bd-e1860d39b5f6 loglevel=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: LENOVO product: 20202 v: Lenovo IdeaPad Z500
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad Z500
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT
serial: <superuser required> UEFI: LENOVO v: 71CN52WW(V1.22)
date: 01/24/2013
ID-1: BAT1 charge: 0 Wh (0.0%) condition: 4.3/N/A Wh volts: 11.7 min: 14.4
model: LENOVO PABAS0241231 type: Li-ion serial: <filter> status: N/A
Info: model: Intel Core i7-3632QM bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2076 high: 2196 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1742 2: 2196 3: 2095
4: 1803 5: 2195 6: 2195 7: 2195 8: 2191 bogomips: 35121
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Lenovo driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:1292
class-ID: 0302
Device-3: Chicony Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 3-4:2 chip-ID: 04f2:b35d class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
loaded: N/A note: try sudo/root display-ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: XWAYLAND0 res: 1366x768 hz: 60 dpi: 99
size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:0888 class-ID: 0280
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 8087:07da class-ID: e001
Report: bt-adapter ID: hci1 rfk-id: 4 state: up address: <filter>
Local Storage: total: 1.82 TiB used: 205.19 GiB (11.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM014-1EJ164
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVD1
ID-1: / raw-size: 922.46 GiB size: 922.46 GiB (100.00%)
used: 205.14 GiB (22.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-551e16bb-03e7-4bf4-83c3-40579df2ea66
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 44 MiB (17.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.46 GiB size: 922.46 GiB (100.00%)
ID-4: /var/log raw-size: 922.46 GiB size: 922.46 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.46 GiB size: 922.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 298.5 MiB (3.8%)
mapped: luks-fbbf49a3-e58e-445b-a8bd-e1860d39b5f6
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 360 Uptime: 1h 52m wakeups: 2 Memory: 7.62 GiB
used: 5.47 GiB (71.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1528 lib: 369 Shell: fish
v: 3.3.1 running-in: guake inxi: 3.3.11
