╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.16.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=020820c9-e22c-430e-ac14-7b5d98c1f72c rw [email protected]
resume=UUID=2d00326d-c318-4a93-ae74-b577b05ac97c loglevel=3
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C37 v: 2.0
serial: <superuser required> Chassis: type: 3 v: 2.0
Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.E0
date: 06/22/2021
ID-1: hidpp_battery_0 charge: 76% condition: N/A volts: 4.0 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2346 high: 3908 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2057
3: 2096 4: 2057 5: 2196 6: 2200 7: 2198 8: 2178 9: 3908 10: 2136 11: 2057
12: 2057 13: 2199 14: 2201 15: 2199 16: 2200 bogomips: 115203
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.44.0
5.16.15-zen1-1-zen LLVM 13.0.1)
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: GYROCOM C&C Fiio E10 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 1852:7022
class-ID: 0102
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 8087:0aa7 class-ID: e001
address: <filter>
Local Storage: total: 1.58 TiB used: 39.07 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: Ultra 3D NVMe
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 211070WD
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra II 240GB
type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 929.07 GiB size: 929.07 GiB (100.00%)
used: 38.43 GiB (4.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 929.07 GiB size: 929.07 GiB (100.00%)
ID-4: /opt raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 652.3 MiB (0.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-5: /var/log raw-size: 929.07 GiB size: 929.07 GiB (100.00%)
ID-6: /var/tmp raw-size: 929.07 GiB size: 929.07 GiB (100.00%)
ID-1: swap-1 type: partition size: 1.95 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: swap-2 type: zram size: 31.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 66.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 809
Processes: 410 Uptime: 21h 50m wakeups: 30 Memory: 31.33 GiB
used: 5.79 GiB (18.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1171 lib: 302 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-20
Last full system update: 2022-03-20 ↻
I've installed Garuda previously and had no problems with my blue yeti nano, however on this install I'm finding it doesn't show up in my KDE audio settings. I don't really have any experience with PipeWire for debugging these kinds of issues, so I have no idea how to go about getting it working (or even seeing if the drivers are there). I was wondering if somebody could help me get it working.
Not 100% sure this is the correct category to post this under, but it seemed like the most relevant one.
