installed linux-zen & linux kernel along with headers and ran grub-mkconfig -o /boot/grub/grub.cfg then restarted... and now it shows
failed to start Light Display Manager
failed to activate swap SWAP Block/Partition
what to do
what to do
boot to live usb. open garuda boot repair. select the partition garuda is installed and reinstall grub then create config again with the same tool.
?EnOS / Arch style?
Install
sudo pacman -Syu update-grup
and save time …
#!/bin/sh
set -e
exec grub-mkconfig -o /boot/grub/grub.cfg "$@"
then use always
sudo update-grub
not fixed
still same issue
when i type startx in tty nothing happens
trying to use the last snapshot and it worked
