For some unknown reason latte, nextcloud and many other things dont seem to work anymore. I have gone back to a previous snapshot and still alot seems bricked corrupted. ( EDIT: Can't "brick" non-hardware)
For example backgrounds have been completely reset, and on boot i get asked to open up a new kdewallet for nextcloud. I have no idea what happend, yesterday everything was fine.
[email protected] in ~ took 5ms
[🔍] × garuda-inxi
Kernel: 5.17.5-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c62e35b2-c344-4a40-bff0-abcde7e3ec22 rw [email protected]
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.64
date: 04/08/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2838 high: 3590 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2227 2: 2383
3: 2874 4: 2869 5: 2874 6: 2878 7: 3590 8: 2871 9: 2877 10: 2878 11: 2870
12: 2876 bogomips: 88798
STIBP: always-on, RSB filling
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DP-1,DVI-D-1,HDMI-A-1 empty: DVI-D-2
bus-ID: 2b:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-1.2:4 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 4480x2160 s-dpi: 96 s-size: 1185x571mm (46.65x22.48")
s-diag: 1315mm (51.79")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: primary,top-left
model: Idek Iiyama PL2480H serial: <filter> built: 2013 res: 1920x1080
hz: 60 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: Acer XF272U serial: <filter> built: 2018 res: 2560x1440 hz: 144
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l model: Kamvas Pro 13
built: 2019 res: 1920x1080 hz: 60 dpi: 141 gamma: 1.2
size: 345x195mm (13.58x7.68") diag: 396mm (15.6") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM
3.44 5.17.5-zen1-2-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
lanes: 16 bus-ID: 2b:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.5-zen1-2-zen running: yes
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:0034 class-ID: 0280
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
Local Storage: total: 2.82 TiB used: 181.68 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR021
temp: 44.9 C scheme: GPT
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 480GB
type: SSD serial: <filter> rev: 04RL scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Intenso model: SSD Sata III
type: SSD serial: <filter> rev: 1D scheme: GPT
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 31 GiB (62.0%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 399.26 GiB size: 399.26 GiB (100.00%)
used: 150.68 GiB (37.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
used: 31 GiB (62.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1202
Processes: 355 Uptime: 1m wakeups: 0 Memory: 15.61 GiB
used: 2.4 GiB (15.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1484 lib: 397 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-01-21
Last full system update: 2022-05-11
