Kernel: 6.1.47-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=22b0128f-231d-4f5b-9a0d-f394e297be0f rw rootflags=subvol=@
Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.2 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
UEFI: Insyde v: 1.13 date: 02/11/2019
ID-1: BAT1 charge: 35.9 Wh (99.7%) condition: 36.0/48.9 Wh (73.6%)
volts: 16.3 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0 type: Li-ion
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2005 high: 2795 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1506 2: 1480
3: 2795 4: 1763 5: 1450 6: 1931 7: 2669 8: 2452 bogomips: 31948
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
temp: 43.0 C
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 44.0 C
Device-3: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:a060
Display: x11 server: X.Org v: 21.1.8 compositor: marco v: 1.26.2 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.1.47-1-lts) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.1.47-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 42.0 C
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 04ca:3016 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 4.2
Local Storage: total: 5.57 TiB used: 4.96 TiB (89.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
model: WD50NDZM-59PW8S1 size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 2003
ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 40.42 GiB (42.1%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
used: 859 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 714.16 GiB (78.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
used: 40.42 GiB (42.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.26 GiB used: 2.1 GiB (6.9%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
GPU: device: amdgpu temp: 45.0 C device: amdgpu temp: 43.0 C watts: 9.10
Processes: 352 Uptime: 19h 57m wakeups: 17 Memory: total: 32 GiB note: est.
available: 30.26 GiB used: 8.21 GiB (27.1%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 15.0.7 Packages: 1680 pm: pacman pkgs: 1674 libs: 519
tools: gnome-software,octopi,pamac,paru,yay pm: flatpak pkgs: 6 Shell: Bash
v: 5.1.16 running-in: mate-terminal inxi: 3.3.29
System install date: 2023-07-06
Last full system update: 2023-08-28 ↻
All of a sudden, Aqualung has no audible output, just silence while it plays. I installed Mixxx and it's silent, too. VLC does play music audibly.
What's going on?
