Whenever I'm playing audio I can hear a soft white noise like sound. After I quit playing audio the noise quickly disappears, but reappears when I start playing audio again. I assume the suspending of the audio is because of some power-saving feature.
I'm using KZ ES4 earphones, if that was relevant.
I've tried reducing the gain on Headphones and PCM using alsamixer, but this did not seem to help.
inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=57e0882a-9290-426d-9bf9-747ae5b39325 rw rootflags=subvol=@
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Micro-Star product: GF65 Thin 10SER v: REV:1.0
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W1IMS.50B date: 05/19/2020
ID-1: BAT1 charge: 33.7 Wh (80.6%) condition: 41.8/51.3 Wh (81.6%)
volts: 12.1 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
status: N/A
status: Discharging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.2
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 29.83 GiB (6.3%)
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21111000 temp: 28.9 C scheme: GPT
used: 29.82 GiB (6.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 46.0 C mobo: N/A
Processes: 322 Uptime: 42m wakeups: 3 Memory: 15.45 GiB
used: 3.37 GiB (21.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1681 lib: 487 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
