.%;888:8898898: honza@honza-garuda-gaming-laptop
x;XxXB%89b8:b8%b88: --------------------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: 82LU (Yoga 9 14IAP7)
.tt8x .d x88; Kernel: 6.12.8-zen1-1-zen
.@8x8; .db: xx@; Uptime: 18 mins
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 2542 (pacman)[stable]
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish 3.7.1
,888S pd! Resolution: 3840x2400
8X88/ q DE: KDE Plasma 6.2.5
8X88/ WM: KWin (Wayland)
GBB. WM Theme: Sweet-Dark
x%88 d888@8@X@X@X88X@@XX@@X@8@X. Theme: Dr460nized (Sweet) [Qt], Sweet-Dark [GTK2/3/4]
dxXd dB8b8b8B8B08bB88b998888b88x. Icons: BeautyLine [Qt], BeautyLine [GTK2/3/4]
dxx8o .@@;. Terminal: konsole 24.12.0
dx88 .t@x. Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad. CPU: 12th Gen Intel(R) Core(TM) i7-1260P (16) @ 4.70 GHz
.d988999889889899dd. GPU: Intel Iris Xe Graphics @ 1.40 GHz [Integrated]
Memory: 10436 MiB / 15711 MiB
╭─honza@honza in ~
╰─λ garuda-inxi
Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=74ef75ea-eca0-42fb-a504-76bc2f1cf7dc rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
Type: Convertible System: LENOVO product: 82LU v: Yoga 9 14IAP7
serial: <superuser required> Chassis: type: 31 v: Yoga 9 14IAP7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_82LU_BU_idea_FM_Yoga 9
14IAP7 uuid: <superuser required> UEFI: LENOVO v: HNCN46WW
date: 09/08/2023
ID-1: BAT0 charge: 44.0 Wh (66.2%) condition: 66.5/75.0 Wh (88.7%)
power: 43.9 W volts: 14.9 min: 15.5 model: Celxpert L21C4PH0 type: Li-poly
serial: <filter> status: discharging cycles: 185
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x435
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 79872
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3
chip-ID: 30c9:0057 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a6 memory: 7.49 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu
name: Intel Iris Xe Graphics (ADL GT2) driver: N/A device-ID: 8086:46a6
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api with: aoss
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: see --recommends
Local Storage: total: 953.87 GiB used: 70.54 GiB (7.4%)
model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: CL1QGXA7 temp: 41.9 C scheme: GPT
used: 70.53 GiB (7.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 4.7 MiB (1.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.34 GiB used: 2.89 GiB (18.8%)
System Temperatures: cpu: 64.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.34 GiB
used: 10.31 GiB (67.2%)
Processes: 370 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
image: 6.13 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 2542 libs: 626 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date: 2025-01-07
Last full system update: 2025-01-09 ↻
╭─honza@honza in ~ took 3s
╰─λ
why do the snapshhots look so big in qdirstat? How can I easily configure the automatical-snapshot making?
