Hello,
Yesterday after updating my system using the "upd" fish alias I had to restore a snapshot because booting the OS would end up in a black screen after the garuda loading screen. Tried ctrl+alt+f2 and unplugging the hdmi but they didn't work, well whatever. So I booted into a old snapshot and in the timeshift application I restored the booted snapshot, but now whenever I boot into the system normally I get this notification. System also feels sluggish but that might be related the to the system update, I'll wait a couple weeks for a new updates and if those don't work I'll do a reinstall. Just wondering if there is something I should do about this notification.
Hey, thank you for replying.
I think I've done all of those steps correctly already but I'll make sure by listing it again.
I booted to a working snapshot from grub
I restored the working snapshot from timeshift
I rebooted and I got a working system again
But still I'm getting the notification that I've booted into a snapshot "original posts picture" I don't think it's harmful in anyway but still kind of odd.
Hello, good Freitag and thanks for the reply.
I did a another system upgrade and grub-update but no change.
I'm pretty sure the grub was updated when I restored the snapshot because without it I would still be booting into the broken one.
Thank you
I've been blind this whole time, there was a second entry in my grub for /dev/sdc2/ where my install is located. How can I fix this and only have this install show up in grub?
Thank you very much
Okey, this fixes that the first selection in grub menu is right but the /dev/sdc2 still stays there. I think this is a "none problem" but just letting everyone else who might see this in the future know.
Thanks for your support @ETO
after I run this "grub-install --target=x86_64-efi --efi-directory=/boot"
I get this error "Installing for x86_64-efi platform.
grub-install: error: /boot doesn't look like an EFI partition."
