Hello Everyone
So I made the successful change to 'Raptor'. Everything i can find is good except one very small query. When I open Snapper tools the theme is not dark but light. It is the only window like this. Everything else is dark and all the selected themes are the correct ones.
I've Google and fiddled and tried to help myself.
Can I make it dark?
Garuda-Inxi
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0 serial: N/A
UEFI: American Megatrends v: 8.5 date: 11/01/2018
Info: model: AMD Athlon X4 860K socket: FM2 (P0) note: check bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3700 min/max: 1700/3700 boost: enabled
base/boost: 3700/3700 scaling: driver: acpi-cpufreq governor: performance
volts: 1.3 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
bogomips: 29543
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: PC Partner / Sapphire
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 56.0 C
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 8-2:3
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 950x285mm (37.40x11.22")
s-diag: 992mm (39.05")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell S2721H
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell P2217
serial: <filter> built: 2017 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 460 Graphics
(polaris11 LLVM 15.0.7 DRM 3.49 6.2.7-zen1-1-zen) direct-render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: PC Partner / Sapphire driver: snd_hda_intel bus-ID: 8-2:3 v: kernel
pcie: chip-ID: 046d:085e class-ID: 0300 gen: 3 speed: 8 GT/s
serial: <filter> lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0
Device-2: Creative Labs EMU10k1 [Sound Blaster Live! Series]
driver: snd_emu10k1 v: kernel bus-ID: 04:05.0 chip-ID: 1102:0002
class-ID: 0401
Device-3: Logitech BRIO Ultra HD Webcam type: USB
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.35 TiB used: 480.99 GiB (34.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
family: Micron Client SSDs size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: MU05 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 166d 17h cycles: 1481
written: 22.72 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1
rev: MU05 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 22d 12h cycles: 788
written: 32.44 TiB
model: WD10EALX-009BA0 family: Blue size: 931.51 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: N/A
serial: <filter> rev: 1H15 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 295d 13h cycles: 1979
used: 25.65 GiB (11.5%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 612 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
maj-min: 8:18
maj-min: 8:18
maj-min: 8:18
ID-1: swap-1 type: zram size: 15.58 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 34.2 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1103
Processes: 287 Uptime: 1d 1h 28m wakeups: 0 Memory: 15.58 GiB
used: 4.11 GiB (26.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1381
libs: 372 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-14
Last full system update: 2023-03-21 ↻
Windows dual boot: Yes
Many restarts have not helped.
