Hello! I have a strange issue which I haven’t seen elsewhere. When I open Snapper Tools, the program crashes when I click the Settings button. I grabbed the console command from my task manager, and got this output:
$ pkexec /usr/lib/snapper-tools-pkexec gui snapper-tools
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
"ca2fa708-e61a-4167-9312-ffbc040fa3bd"
"Mounting ca2fa708-e61a-4167-9312-ffbc040fa3bd"
Segmentation fault (core dumped)
The last line (Segmentation fault (core dumped)) only appears after I click Settings and the program crashes. I’m not sure what steps I should take to resolve this issue. Any troubleshooting steps would be appreciated. Here is the output of my garuda-inxi:
$ garuda-inxi
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ca2fa708-e61a-4167-9312-ffbc040fa3bd rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=6675bcad-60ed-4f60-bc3a-1544295ee925 loglevel=3
amdgpu.ppfeaturemask=0xffffffff usbcore.autosuspend=-1
usbcore.autosuspend_delay_ms=-1 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: lxlock,xautolock vt: 7
Type: Desktop Mobo: ASUSTeK model: P6T SE v: Rev 1.xx
BIOS: American Megatrends v: 0908 date: 09/21/2010
Info: model: Intel Core i7 920 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1A (26) stepping: 5 microcode: 0x1D
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2689 high: 2832 min/max: 1600/2668 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2806 2: 2695
3: 2832 4: 2807 5: 2806 6: 2807 7: 2832 8: 1927 bogomips: 42762
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 64.0 C
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,left model: Acer XF243Y
serial: <filter> built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: Acer XF243Y P
serial: <filter> built: 2021 res: 1920x1080 hz: 144 dpi: 93 gamma: 1.2
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.0-devel
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 18.1.8 DRM 3.57 6.10.6-zen1-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
v: 24.3.0-devel (git-db39685e31) device-ID: 1002:67df surfaces: xcb,xlib
device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 128 bits)
driver: mesa llvmpipe v: 24.3.0-devel (git-db39685e31) (LLVM 18.1.8)
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 6-2:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off
tools: qjackctl
Server-3: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e800
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.3 TiB used: 728.76 GiB (31.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Addlink
model: M.2 PCIE G3x4 NVMe size: 953.87 GiB block-size: physical: 512 B
fw-rev: ECFM32.1 temp: 33.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
ID-1: / raw-size: 702.65 GiB size: 702.65 GiB (100.00%)
used: 560.12 GiB (79.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot raw-size: 1 GiB size: 1 GiB (100.00%) used: 581.1 MiB (56.7%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 464.75 GiB size: 464.75 GiB (100.00%)
used: 168.07 GiB (36.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 702.65 GiB size: 702.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 702.65 GiB size: 702.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.67 GiB used: 776.2 MiB (6.5%)
ID-2: swap-2 type: partition size: 12.8 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C mobo: 46.0 C gpu: amdgpu temp: 64.0 C
Fan Speeds (rpm): cpu: 1834 psu: 0 case-1: 1288 case-2: 0 gpu: amdgpu
fan: 907
Power: 12v: 12.14 5v: N/A 3.3v: 3.28 vbat: N/A gpu: amdgpu watts: 43.12
Memory: total: 12 GiB available: 11.67 GiB used: 7.43 GiB (63.7%)
Processes: 370 Power: uptime: 15m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 4.63 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 256
Packages: pm: pacman pkgs: 2013 libs: 549 tools: pamac,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
running-in: xfce4-terminal inxi: 3.3.35
System install date: 2021-09-22
Last full system update: 2024-08-29
