Snapper fails to perform snapshots after snapshot restore.
sudo snapper -c root create --description "try"
results in
IO Error (.snapshots is not a btrfs subvolume).
The same issue occurs during pacman snapshot hooks.
Output of garuda-inxi
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=71b9d90c-48e3-4e87-bd2a-e0f7c4c69b1d rw [email protected]
loglevel=3 ibt=off
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Micro-Star product: GF63 Thin 9SC v: REV:1.0
Mobo: Micro-Star model: MS-16R3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R3IMS.108 date: 03/26/2020
ID-1: BAT1 charge: 44.2 Wh (96.9%) condition: 45.6/51.3 Wh (88.9%)
volts: 12.8 min: 11.4 model: MSI Corp. MS-16R3 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 bogomips: 38400
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
compositor: gnome-shell driver: X: loaded: modesetting,nvidia gpu: i915
display-ID: :1 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
v: 4.6 Mesa 22.1.1 direct render: Yes
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
bus-ID: 1-14:4 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Local Storage: total: 1.43 TiB used: 149.77 GiB (10.2%)
model: PC SN520 SDAPNUW-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 320 GiB size: 320 GiB (100.00%) used: 67.51 GiB (21.1%)
used: 28.8 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 320 GiB size: 320 GiB (100.00%)
used: 67.51 GiB (21.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 320 GiB size: 320 GiB (100.00%)
ID-5: /var/tmp raw-size: 320 GiB size: 320 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 2.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 63.0 C pch: 67.0 C mobo: N/A
Processes: 382 Uptime: 22m wakeups: 3 Memory: 15.47 GiB
used: 7.16 GiB (46.3%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: apt: 0 pacman: 1386 lib: 333 flatpak: 0 Shell: Zsh
v: 5.9 running-in: gnome-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-04-07
Last full system update: 2022-06-06
Failed units: keychron.service
Output of mount
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=8084776k,nr_inodes=2021194,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
/dev/nvme0n1p3 on / type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=1925,subvol=/@)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18054)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
/dev/nvme0n1p3 on /home type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=257,subvol=/@home)
/dev/nvme0n1p3 on /root type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=258,subvol=/@root)
/dev/nvme0n1p3 on /srv type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=259,subvol=/@srv)
tmpfs on /tmp type tmpfs (rw,noatime,inode64)
/dev/nvme0n1p3 on /var/cache type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=260,subvol=/@cache)
/dev/nvme0n1p3 on /var/log type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=261,subvol=/@log)
/dev/nvme0n1p3 on /var/tmp type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=262,subvol=/@tmp)
/dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/sda1 on /home/shailesh/BIGDATA type ext4 (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1622612k,nr_inodes=405653,mode=700,uid=1000,gid=1000,inode64)
espanso on /tmp/.mount_espansNpWcHi type fuse.espanso (ro,nosuid,nodev,relatime,user_id=1000,group_id=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
espanso on /tmp/.mount_espanswRX04O type fuse.espanso (ro,nosuid,nodev,relatime,user_id=1000,group_id=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/nvme0n1p3 on /mnt type btrfs (rw,relatime,compress=zstd:3,ssd,discard=async,space_cache=v2,autodefrag,subvolid=5,subvol=/)
