Snapcraft build for flutter fails
Hey there,
I am creating a desktop application for linux in flutter.
I want to release it on snap (mostly because flutter provides a little how to and I don't looked for alternatives).
When snapcrafting, I get following exception:
/root/snap/flutter/common/flutter/.pub-cache/hosted/pub.dartlang.org/path_provider_windows-2.0.3/
[  +60 ms] 💪 Building with sound null safety 💪
[   +8 ms] Building Linux application...
[  +11 ms] executing: [build/linux/x64/release/] cmake -G Ninja -DCMAKE_BUILD_TYPE=Release -DFLUTTER_TARGET_PLATFORM=linux-x64
/root/parts/nextcloud-password-client/build/linux
[ +827 ms] -- The CXX compiler identification is Clang 6.0.0
[  +13 ms] -- Check for working CXX compiler: /snap/flutter/current/usr/bin/clang++
[ +121 ms] -- Check for working CXX compiler: /snap/flutter/current/usr/bin/clang++ -- works
[   +1 ms] -- Detecting CXX compiler ABI info
[ +107 ms] -- Detecting CXX compiler ABI info - done
[  +11 ms] -- Detecting CXX compile features
[ +818 ms] -- Detecting CXX compile features - done
[   +5 ms] -- Found PkgConfig: /snap/flutter/current/usr/bin/pkg-config (found version "0.29.1")
[        ] -- Checking for module 'gtk+-3.0'
[  +15 ms] --   Found gtk+-3.0, version 3.22.30
[  +67 ms] -- Checking for module 'glib-2.0'
[  +17 ms] --   Found glib-2.0, version 2.56.4
[  +35 ms] -- Checking for module 'gio-2.0'
[  +14 ms] --   Found gio-2.0, version 2.56.4
[  +47 ms] -- Checking for module 'libsecret-1>=0.18.4'
[   +4 ms] --   No package 'libsecret-1' found
[        ] -- Configuring incomplete, errors occurred!
[        ] See also "/root/parts/nextcloud-password-client/build/build/linux/x64/release/CMakeFiles/CMakeOutput.log".
[   +1 ms] CMake Error at /snap/flutter/101/usr/share/cmake-3.10/Modules/FindPkgConfig.cmake:419 (message):
[   +1 ms]   A required package was not found
[        ] Call Stack (most recent call first):
[        ]   /snap/flutter/101/usr/share/cmake-3.10/Modules/FindPkgConfig.cmake:597 (_pkg_check_modules_internal)
[        ]   flutter/ephemeral/.plugin_symlinks/flutter_secure_storage_linux/linux/CMakeLists.txt:13 (pkg_check_modules)
[   +5 ms] Building Linux application... (completed in 2,130ms)
[        ] "flutter linux" took 7,739ms.
[   +3 ms] Unable to generate build files
[   +1 ms]
           #0      throwToolExit (package:flutter_tools/src/base/common.dart:10:3)
           #1      _runCmake (package:flutter_tools/src/linux/build_linux.dart:155:5)
           <asynchronous suspension>
           #2      buildLinux (package:flutter_tools/src/linux/build_linux.dart:75:5)
           #3      BuildLinuxCommand.runCommand (package:flutter_tools/src/commands/build_linux.dart:88:5)
           #4      FlutterCommand.run.<anonymous closure> (package:flutter_tools/src/runner/flutter_command.dart:1130:27)
           #5      AppContext.run.<anonymous closure> (package:flutter_tools/src/base/context.dart:150:19)
           #6      CommandRunner.runCommand (package:args/command_runner.dart:209:13)
           #7      FlutterCommandRunner.runCommand.<anonymous closure> (package:flutter_tools/src/runner/flutter_command_runner.dart:288:9)
           #8      AppContext.run.<anonymous closure> (package:flutter_tools/src/base/context.dart:150:19)
           #9      FlutterCommandRunner.runCommand (package:flutter_tools/src/runner/flutter_command_runner.dart:236:5)
           #10     run.<anonymous closure>.<anonymous closure> (package:flutter_tools/runner.dart:62:9)
           #11     AppContext.run.<anonymous closure> (package:flutter_tools/src/base/context.dart:150:19)
           #12     main (package:flutter_tools/executable.dart:92:3)
[  +67 ms] ensureAnalyticsSent: 57ms
[   +2 ms] Running shutdown hooks
[        ] Shutdown hooks complete
[        ] exiting with code 1
Failed to run 'flutter build linux --release -v -t lib/main.dart' for 'nextcloud-password-client': Exited with code 1.
Verify that the part is using the correct parameters and try again.
is it possible that the exception is thrown because libsecret-1-0 is the name of the ubuntu package and not the arch one? If so, how can I craft the snap on arch than?
I know that there is flutter_secured_storage-linux simlink is mentioned. But if that would be the problem I'd assume that the normal build would'nt work eiter.
Try installing libsecret
sudo pacman -S libsecret
Hey,
thanks for the answer.
But unfortunately it is already installed, as I needed it to test the app :-/
Wait, this means you explicitly marked libsecret-1 as dependency? I am not really sure but as far as I know, libsecret-1 is for debian based and libsecret is for Arch based.
So, is there any way to mark it as an “alternative” dependency?
After 2 more hours of search I found the "try" command.
If you use "try: -libsecret-1-0 else: -libsecret"
snap will use libsecret as fallbakc if libsecret-1-0 is not found.
Your "alternative" lead me to seach fo rsnap different distro which lead me finally to the advanced grammar section from offical documentation -.-
So, it's solved now I guess.
And btw, it's a new thing you learned. Good for you!
