Maybe someone can help with a small unimportant issue I have with Icons in Dolphin on Plasma 6.0.2. Previously ISO files had a nice Candy ISO/CD Icon. This has changed to a text document Icon which is not so nice.
Additionally, and I think this might have been mentioned before, the free/used indicator bottom right is squished up.
As far as I can tell my system is up to date.
Are these an easy fix?
My Inixi
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0 serial: N/A
uuid: 00000000-0000-0000-0000-4ccc6a46edf4 UEFI: American Megatrends v: 8.5
date: 11/01/2018
Info: model: AMD Athlon X4 860K socket: FM2 (P0) note: check bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3700 min/max: 1700/3700 boost: enabled
base/boost: 3700/3700 scaling: driver: acpi-cpufreq governor: performance
volts: 1.3 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
bogomips: 29543
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: PC Partner / Sapphire
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 37.0 C
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2
chip-ID: 046d:085e class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell S2721H
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell S2721H
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 460 Graphics
(radeonsi polaris11 LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen)
device-ID: 1002:67ef memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 460 Graphics (RADV POLARIS11) driver: mesa radv
v: 24.0.3-arch1.2 device-ID: 1002:67ef surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD FCH Azalia vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: n/a (root, process) with:
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.38 TiB used: 419.08 GiB (29.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
family: Micron Client SSDs size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: MU05 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 152d 19h cycles: 1545
written: 24.1 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1
fw-rev: MU05 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 8d 13h cycles: 852
written: 39.9 TiB
model: WD10EALX-009BA0 family: Blue size: 931.51 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1H15 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 281d 14h cycles: 2043
ID-4: /dev/sdd maj-min: 8:48 vendor: Generic model: STORAGE DEVICE
size: 29.72 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 9407 scheme: MBR
used: 50.12 GiB (22.4%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 27.2 MiB (9.1%) fs: vfat block-size: 512 B dev: /dev/sdb1
maj-min: 8:17
maj-min: 8:18
maj-min: 8:18
maj-min: 8:18
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.1 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1056
Memory: total: 16 GiB available: 15.58 GiB used: 3.98 GiB (25.5%)
Processes: 264 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1666 libs: 453 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2024-03-04
Last full system update: 2024-03-29
Windows dual boot: Yes
DE: KDE Plasma 6.0.2
WM: KWin (X11)
WM Theme: Sweet-Dark
Theme: kvantum-dark (Sweet) [QT], Sweet-Dark [GTK2/3/4]
Icons: BeautyLine [QT], BeautyLine [GTK2/3/4]
Font: Fira Sans (10pt) [QT], Fira Sans (10pt) [GTK2/3/4]
