Hi guys.
I just moved from Fedora to Garuda, and its look amazing!!! Well done.
But its slow AF its moving like i have 10fps.
Any advice here?
System: Kernel: 5.12.13-zen1-2-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9d2ab545-ce0f-4f66-8e27-6695233aac0c rw
systemd.unified_cgroup_hierarchy=1 loglevel=3 nouveau.modeset=0
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME Z270-A v: Rev 1.xx serial: <filter> UEFI-[Legacy]: American Megatrends
v: 1302 date: 03/15/2018
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4085 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4085 2: 4028 3: 4039 4: 4069 5: 4057 6: 4048 7: 4043
8: 4062
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia v: 460.84 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Lenovo 500 RGB Camera type: USB driver: uvcvideo bus-ID: 1-6:5 chip-ID: 17ef:482f class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.7x11.9") s-diag: 1102mm (43.4")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.84 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: TEAC US-1x2 type: USB driver: snd-usb-audio bus-ID: 1-5:4 chip-ID: 0644:805b class-ID: 0102
Sound Server-1: ALSA v: k5.12.13-zen1-2-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: f000 bus-ID: 00:1f.6
chip-ID: 8086:15b8 class-ID: 0200
Drives: Local Storage: total: 704.24 GiB used: 32.38 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G7 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: PSF100C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 40WD scheme: MBR
Partition: ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 32.38 GiB (7.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 32.38 GiB (7.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 32.38 GiB (7.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 32.38 GiB (7.0%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.95 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 16%
Info: Processes: 275 Uptime: 1h 24m wakeups: 0 Memory: 15.57 GiB used: 5.73 GiB (36.8%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: 1920 apt: 1 pacman: 1914 lib: 376 snap: 5
Shell: fish v: 3.2.2 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
