Slow steam download speed
I’ve tried all fixes suggested: dnsmasq, disabled ipv6, disabled http2. My usual download speed on windows is around 50 MB/s, on Garuda it’s about 10 MB/s. I tried to use Arch Linux instead of Garuda, same issue. A speed test gives the same speed as in windows. After I initially disabled ipv6 the download speed went to the usual 50 MB/s, but the next time I booted the pc it went back to 10 MB/s. Out of curiosity I booted my steam deck, entered desktop mode and hooked it to the same ethernet cable, 50 MB/s. So My thinking is somewhere something isn’t setup right. I’m using runtime Steam, not Native.
Kernel: 6.15.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=2cb85728-873f-481b-b2de-163013fbc6d2 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop Mobo: Micro-Star model: MAG X870E TOMAHAWK WIFI (MS-7E59)
v: 2.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 2.A30 date: 01/06/2025
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2985 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2985 2: 2985 3: 2985
4: 2985 5: 2985 6: 2985 7: 2985 8: 2985 9: 2985 10: 2985 11: 2985 12: 2985
13: 2985 14: 2985 15: 2985 16: 2985 bogomips: 150399
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, HDMI-A-1,
HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3,
Writeback-2 bus-ID: 7c:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 43.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Acer XV240Y serial: <filter> built: 2021 res:
mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 20.1.7 DRM 3.63 6.15.5-zen1-1-zen) device-ID: 1002:7550
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.1.5-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.1.5-arch1.1 device-ID: 1002:13c0 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 20.1.7 256 bits) driver: mesa llvmpipe
v: 25.1.5-arch1.1 (LLVM 20.1.7) device-ID: 10005:0000 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
[Rembrandt/Strix] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 7c:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 7c:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:2
chip-ID: 0db0:cd0e class-ID: 0300
API: ALSA v: k6.15.5-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
chip-ID: 10ec:8126 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 2 bus-ID: 0a:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-12:5 chip-ID: 0489:e10a
Local Storage: total: 2.73 TiB used: 109.2 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Corsair model: MP700 PRO
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EQFM22.3 temp: 50.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: MP600 ELITE
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFM11.2 temp: 39.9 C
used: 109.2 GiB (11.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.2 C mobo: N/A
GPU: device: amdgpu temp: 43.0 C device: amdgpu temp: 38.0 C mem: 38.0 C
fan: 3 watts: 21.00
Memory: total: 32 GiB note: est. available: 30.4 GiB used: 4.88 GiB (16.0%)
Processes: 422 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1835 libs: 563 tools: octopi,paru,yay
Compilers: clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish
Garuda (2.7.3-1):
System install date:     2025-07-06
Last full system update: 2025-07-08
Check with speedtest++, fast.com,
exclude also the bit and byte “problem” :wink:
be sure no other apps use the network.
500 Mbps. Network’s fine
Ubisoft Connect downloads at around 60 MB/s, similar speed to windows.
I had neglected to configure dnsmasq porpertly, now it seems to be working. Steady 60 MB/s even after restarting the computer.
Can you share, what is this property that was and what it is now, which made the whole difference? Thank you.
Most likely if this happens it’s a DNS issue like it was already mentioned.
I also had this issue, and the fix was also related to DNS.
I have a pi-hole and I was fiddling with its configuration and broke it without realizing. Steam was downloading at about 5-10 mb/s or even under 1 mb/s.
Quick fix: Manually set the dns servers to 8.8.8.8 and 8.8.4.4 in System Settings → WiFi & Internet → WiFi & Networking → your connectino → IPv4 → DNS Servers
Better fix: Find out what dns setting is misconfigured on your network. In my case it was a pi-hole that I broke. Fixed it and now everything works fine, Steam downloads at full speed.
This topic was automatically closed after 21 hours. New replies are no longer allowed.
