Hello Garuda users!
i recently got started on garuda after trying distro after distro trying to find the perfect one for me and when i found out about garuda i instantly installed it and deleted the distro i was using which i thought was perfect for me but seems it wasnt after all
but well let me go straight to my issue:
so since i have installed linux on my computer my internet has been a little bit slow even tho in tests in speedtest.net and fast.com says i got 200mbps [speed i have in my internet plan] i seem to not be able to use more than 25mbps downloading apps, games etc etc i have tried changing drivers [using a r8168 network card] resetting os many times changing every setting i could find in my network settings/terminal and even up to disabling IPV6 but nothing has worked im posting here in the forums to see if someone can help me out since i got no more options.
information that may be necesary
garuda-inxi:
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.18.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=90c23ed6-e523-4048-9e19-9e0729d47f9b rw [email protected]
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
Mobo: HP model: 8478 v: 70.60 serial: <superuser required> UEFI: Insyde
v: F.25 date: 11/13/2020
ID-1: BAT1 charge: 38.7 Wh (85.1%) condition: 45.5/52.8 Wh (86.2%)
volts: 12.4 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: N/A
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3663 high: 3902 min/max: 800/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 3025 2: 3901 3: 3900
4: 3902 5: 3665 6: 3116 7: 3900 8: 3901 bogomips: 36799
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:1c8d
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 05c8:03bc class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 mapped: eDP-1-1 model: BOE Display 0x07a1 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA
515.57 direct render: Yes
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
Sound Server-1: ALSA v: k5.18.15-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
IF-ID-1: enp0s20f0u4c4i2 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.4 TiB used: 18.74 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C
temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: TEAM T253X2001T
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 7B0 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 18.74 GiB
(3.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 18.74
GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 18.74
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 18.74
ID-1: swap-1 type: zram size: 15.52 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 67.0 C pch: 66.0 C mobo: N/A
Processes: 322 Uptime: 28m wakeups: 6 Memory: 15.52 GiB used: 5.07 GiB
(32.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 Packages: pacman: 1740 lib: 515 flatpak: 0
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-08-01
Last full system update: 2022-08-01 ↻
ethtool eno1:
╭─[email protected] in ~ took 1s
╰─λ ethtool eno1
Settings for eno1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Half 1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: Unknown
netlink error: Operation not permitted
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
inxi -N
╭─[email protected] in ~ took 1ms
╰─λ inxi -N
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
driver: r8168
problem happens while connected to wifi too so its a general network issue it seems
