Hi when my laptop are running on battery and it sleep, there are no way to wake it up with screen image, the only way are to hard reboot.
Some times if i manage to put in the charger, it might wake up as normal with charger plugin.
Is there anyway to fix this?
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0055dfc4-1cdb-45d4-a084-5838e8ae0d24 rw rootflags=subvol=@
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> part-nu: LENOVO_MT_82JU_BU_idea_FM_Legion 5
15ACH6H uuid: <superuser required> UEFI: LENOVO v: GKCN65WW
date: 01/16/2024
ID-1: BAT0 charge: 39.2 Wh (70.9%) condition: 55.3/60.0 Wh (92.1%)
power: 33.3 W volts: 16.4 min: 15.4 model: SMP L20M4PC0 type: Li-poly
serial: <filter> status: charging cycles: 84
ID-2: hidpp_battery_0 charge: 94% condition: N/A volts: 4.1 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
microcode: 0xA50000F
Speed (MHz): avg: 2316 min/max: 400/4463 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2316 2: 2316 3: 2316
4: 2316 5: 2316 6: 2316 7: 2316 8: 2316 9: 2316 10: 2316 11: 2316 12: 2316
13: 2316 14: 2316 15: 2316 16: 2316 bogomips: 102208
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, HDMI-A-1, eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2560
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-2 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 37.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: eDP-2 mapped: eDP-1 model: BOE Display 0x0998 built: 2020
res: 1920x1080 hz: 165 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.12.1-zen1-1-zen) device-ID: 1002:1638
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 565.57.01
device-ID: 10de:2560 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api tools: N/A
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:4852
Local Storage: total: 1.86 TiB used: 418.34 GiB (21.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU020TZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 30.9 C scheme: GPT
ID-1: / raw-size: 1.07 TiB size: 1.07 TiB (100.00%) used: 243.95 GiB (22.2%)
used: 32.1 MiB (33.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.07 TiB size: 1.07 TiB (100.00%)
used: 243.95 GiB (22.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.07 TiB size: 1.07 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.07 TiB size: 1.07 TiB (100.00%)
ID-1: swap-1 type: zram size: 13.5 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.2 C mobo: N/A gpu: amdgpu temp: 39.0 C
Memory: total: 16 GiB note: est. available: 13.5 GiB used: 4.34 GiB (32.2%)
Processes: 425 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.35 GiB services: gsd-power,
Packages: 1464 pm: pacman pkgs: 1450 libs: 461
tools: gnome-software,pamac,paru,yay pm: flatpak pkgs: 14 Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: alacritty inxi: 3.3.36
System install date: 2024-08-12
Last full system update: 2024-11-29
