Hello guys,
I installed on my laptop garuda-dragonized. The issue is when it goes to sleep/suspend the graphics are totally messed up and I need to reboot the laptop to fix it.
I looked for some solutions found this on reddit but I’m getting following error when I run the sudo dracut --force
command:
dracut[I]: Executing: /usr/bin/dracut --force
dracut[F]: Can't write to /boot/efi/6dfdc55b60b34ddea226e7822d2ec527/6.8.9-zen1-2-zen: Directory /boot/efi/6dfdc55b60b34ddea226e7822d2ec527/6.8.9-zen1-2-zen does not exist or is not accessible.
╰─λ garuda-inxi
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=8201d9e1-7c33-41bf-bff1-3b9264795992 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 82JQ v: Legion 5 Pro 16ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ACH6H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82JQ_BU_idea_FM_Legion 5 Pro 16ACH6H
uuid: <superuser required> UEFI: LENOVO v: GKCN64WW date: 12/07/2023
ID-1: BAT0 charge: 71.9 Wh (98.1%) condition: 73.3/80.0 Wh (91.7%)
power: 8.3 W volts: 16.8 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: charging cycles: 73
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 469 high: 1510 min/max: 400/4463 scaling:
4: 400 5: 400 6: 400 7: 400 8: 1510 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 102206
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24dd
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: eDP-1 res: 2560x1600 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:24dd
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Local Storage: total: 953.87 GiB used: 27.46 GiB (2.9%)
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3L1QEXF7 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 660.9 GiB size: 660.9 GiB (100.00%) used: 27.44 GiB (4.2%)
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 660.9 GiB size: 660.9 GiB (100.00%)
used: 27.44 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 660.9 GiB size: 660.9 GiB (100.00%)
ID-5: /var/tmp raw-size: 660.9 GiB size: 660.9 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.9 C mobo: N/A
Memory: total: 16 GiB available: 15.47 GiB used: 2.67 GiB (17.3%)
Processes: 360 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1992 libs: 551 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-30
Last full system update: 2024-05-15
Relevant software: snapper(custom) NetworkManager dracut nvidia-dkms
Any suggestions on how to fix this please?
