Sleep Issue
type or paste code heregaruda-inxi
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b490211f-2fe3-40fa-bb09-ede6ca56b7ae rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS X HERO (WI-FI AC) v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2503
date: 09/25/2020
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 866 high: 901 min/max: 800/4700:4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 800 4: 800
5: 901 6: 900 7: 900 8: 800 9: 800 10: 900 11: 900 12: 900 bogomips: 88796
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 045e:075d class-ID: 0102
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
unloaded: vesa alternate: fbdev,nv gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 159 s-size: 1227x352mm (48.31x13.86")
s-diag: 1276mm (50.26")
Monitor-1: DP-2 pos: right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 3840x2160 hz: 60 dpi: 160
size: 608x345mm (23.94x13.58") diag: 699mm (27.52") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 535.113.01
device-ID: 10de:1b80 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:5 chip-ID: 0b05:185c
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 5.46 TiB used: 1.37 TiB (25.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 30.9 C scheme: MBR
model: WD5000AAKS-00V1A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
model: WD4004FZWX-00GBGB0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A81 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
used: 114.2 GiB (12.3%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 26%
Processes: 320 Uptime: 25m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.83 GiB (15.4%) Init: systemd v: 254
pm: pacman pkgs: 1979 libs: 568 tools: octopi,pamac,paru,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-07-07
Last full system update: 2023-10-14
Relevant software:       timeshift(custom) NetworkManager dracut nvidia-dkms
I have an issue with putting my computer to sleep, about 1 or 2 times a week where the keyboard, mouse and moniters will shut down but the computer itself doesn’t go to sleep and the only way out of it is a hard reboot.
Any ideas on that one?
Is there a particular reason you are booting in legacy mode? The initial few suggestions I can provide are
  1. Visit this post and see if it helps → Waking up from suspend - #3 by BluishHumility If it doesn’t, undo the changes you made to grub and run sudo update-grub again.
  2. Try updating your UEFI to the latest version available by the vendor for you.
  3. Try booting in normal mode if you don’t need legacy for some specific reason. :person_shrugging:
  4. Try the LTS kernel,
Then from grub while booting select advanced options using arrow keys and Enter and in there choose linux-lts.
If none of this helps can you provide us the logs from before you had to hard reboot? Preferably from the start of system entering sleep state to the moment you had to hard reboot. You can paste the logs in garuda’s privatebin or any paste bin of your choice and provide us the link since the logs can be quite lengthy.
I didn’t realize I was.
