dlazar
26 December 2023 20:53
1
I am booting the KDE gamer editions and hooked up my 2015 MBP HDMI output to an external screen. When I leave my machine alone it goes to sleep as per the settings I made for power management, but as I watch things unfold, the machine just comes back to life and sits showing off the Garuda Dragon. I timed it to be about 7 minutes.
So I am suspecting something like wireless networking is waking up the machine? The result is screen burn-in of the Garuda Dragon for I dunno how long, as I now close the lid of the laptop when I really want the machine to go down.
Anyway, what is the process of having a screensaver to save burn-in of my nice screens? And is there a common culprit to look for that wakes a sleeping machine and shows off the splash screen?
Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3ca8b255-f29c-4744-8324-8ca995444357 rw rootflags=subvol=@
quiet resume=UUID=88aa211a-5bdb-49f3-a5f5-d8ac5cf926a3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
serial: <superuser required> UEFI: Apple v: 486.0.0.0.0 date: 08/03/2023
ID-1: BAT0 charge: 58.8 Wh (96.6%) condition: 60.9/74.8 Wh (81.4%)
volts: 12.7 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
status: full cycles: 209
Device-1: hidpp_battery_0 model: Logitech MX Master 3 for Mac
Info: model: Intel Core i5-5287U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2941 high: 3028 min/max: 500/3300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2939 2: 2900 3: 2898
4: 3028 bogomips: 23200
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: HDMI-A-2,eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:162b
alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 3657x1234
display-ID: 0
Monitor-1: HDMI-A-2 pos: right res: 2194x1234 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1463x914 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW
GT3) device-ID: 8086:162b memory: 15.16 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 9 device: 0 type: integrated-gpu name: Intel
Iris Graphics 6100 (BDW GT3) driver: mesa intel v: 23.3.1-arch1.1
device-ID: 8086:162b surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 05ac:8290 class-ID: fe01
Local Storage: total: 465.92 GiB used: 16.54 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: JA0Q scheme: GPT
ID-1: / raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
used: 16.54 GiB (3.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-4: /var/log raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 93.0 C pch: 84.0 C mobo: N/A
Processes: 237 Uptime: 4m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 4.76 GiB (30.6%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1947 libs: 562 tools: octopi,paru Shell: fish
v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-12-24
Last full system update: 2023-12-26
Do you use monochrome screens?
dlazar
26 December 2023 21:59
4
No. The MBP is a spiffy retina display and the external monitor is a nice BENQ 27"
display-ID: 0
Garuda (2.6.22-1):
I assumed that only CRT screens could be burn in and was promptly proven wrong:
OLED and AMOLED are particularly vulnerable. But burn-ins are also known from LCD displays.
Now I understand your concerns.
XDJMV
27 December 2023 00:50
6
maybe you can use the sleep command followed by the amount of time you want to sleep (h, m, s) ?
NaN
27 December 2023 14:29
7
dlazar:
Do you have your bluetooth on while going to sleep? If yes turn it off. That’s usually one reason why laptop wakes up from sleep for a couple of people.
Also in powertop wakeup check if everything is disabled for you? If any are on you can toggle them off and then try to sleep. Don’t worry about making any mistakes here since any changes you make won’t persist reboots. i.e, they will go back to their original state once laptop is restarted. We are just testing things out here.
>> Disabled Wake-on-lan status for device wlp0s20f3
Disabled Wake status for USB device usb3
Disabled Wake status for USB device 3-6
Disabled Wake status for USB device usb1
Disabled Wake status for USB device usb4
Disabled Wake status for USB device 3-10
Disabled Wake status for USB device usb2
To launch powertop,
sudo powertop
to navigate to wakeup use Tab and to exit press Esc . Exiting usually takes a while with powertop.
system
Closed
10 January 2024 14:30
8
