just trying to play skyrim. it won’t launch with proton GE, experimental, 8.0, or 7.0. I verified the integrity of the game files. still wont launch
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1e0ad18c-0993-40e1-b5e4-31a3b75f8dad rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.H0
date: 09/21/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3611 high: 3809 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3586
3: 3600 4: 3600 5: 3600 6: 3600 7: 3599 8: 3600 9: 3593 10: 3600 11: 3600
12: 3600 13: 3600 14: 3809 15: 3600 16: 3600 bogomips: 115198
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.6.6-zen1-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
rfk-block: hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 2.73 TiB used: 415 GiB (14.9%)
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 414.96 GiB (22.3%)
used: 35.5 MiB (11.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 414.96 GiB (22.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 145.2 MiB (0.5%)
System Temperatures: cpu: 52.5 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 60.0 C
Processes: 408 Uptime: 1h 4m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 6.35 GiB (20.3%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1914
pm: pacman pkgs: 1906 libs: 519 tools: pamac,paru pm: flatpak pkgs: 8
Shell: fish v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-10-10
Last full system update: 2023-12-12 ↻
