Sinhala Unicode fonts appearing issue
In my laptop Sinhala language unicode fonts not appear correctly.I attached screenshot below.i want to remove default system unicode font for Sinhala language and need to install font name called Iskola poota.I installed it but it conflict with default sinhala unicode font.so how to solve that?
Screenshot
Please paste the full input/output of the installation command you are using into the thread so we can see where you are getting stuck.
garuda-inxi is also missing.
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fbf098f9-58fd-4f4e-b05f-84f3602c4d0e rw rootflags=subvol=@
resume=UUID=0a7bce65-e75c-4f51-9b94-edde6f2f9e18 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: Hewlett-Packard product: HP ProBook 450 G0
v: A2018CD200 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1949 v: KBC Version 90.0F
serial: <superuser required> BIOS: Hewlett-Packard v: 68IRF Ver. F.63
date: 06/03/2016
ID-1: BAT0 charge: 30.7 Wh (99.0%) condition: 31.0/31.0 Wh (100.0%)
volts: 12.7 min: 11.1 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3078 high: 3180 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3135 2: 2994 3: 3180
4: 3003 bogomips: 20752
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: HDMI-A-1,LVDS-1,VGA-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Mars [Radeon HD 8670A/8670M/8750M / R7 M370]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6600
class-ID: 0300 temp: 58.0 C
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: crocus,radeonsi gpu: i915 display-ID: :0
Screen-1: 0 s-res: 5206x1080 s-dpi: 96 s-size: 1375x285mm (54.13x11.22")
s-diag: 1404mm (55.28")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-center model: VZ239
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
Monitor-2: LVDS-1 pos: primary,bottom-l model: LG Display 0x03d9
built: 2012 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
modes: 1366x768
Monitor-3: VGA-1 pos: top-right model: HP E241i serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
API: OpenGL v: 4.2 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) direct render: Yes
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 1814:3290 class-ID: 0280
lanes: 1 port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.1 chip-ID: 1814:3298
class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 1.13 TiB used: 780.94 GiB (67.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: KingSpec model: P4-240
type: SSD serial: <filter> rev: 0A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 2A scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
used: 18.16 GiB (8.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-3: /var/log raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-4: /var/tmp raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.61 GiB used: 3.18 GiB (41.8%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 71.0 C mobo: N/A gpu: radeon temp: 58.0 C
Processes: 281 Uptime: 5h 25m wakeups: 1 Memory: 7.61 GiB
used: 5.14 GiB (67.5%) Init: systemd v: 252 default: graphical
pkgs: 2022 libs: 566 tools: octopi,pamac,paru,yay Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date:     2022-11-24
Last full system update: 2022-11-25 ↻
Post terminal input and output as text formatted between three ~ in first and last line.
my terminal text
my terminal text
Welcome :slight_smile:
First, reboot.
Second,
