Hey there,
I'm currently facing some signature trouble trying to install wayfire-git, I always get a signature update.
I already tried garuda-update, pacman-key --refresh-keys, garuda-assistant/refresh keys, garuda-assistant/refresh mirrorlist, chaotic/install
Nothing helped, I'm always just getting the same error.
What else am I supposed to do?
Thanks!
Inxi:
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=04b573ca-9c65-4e1f-9b46-52f7108b6193 rw rootflags=subvol=@
Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: FUJITSU product: LIFEBOOK E746 v: 10601186099
serial: <superuser required> Chassis: type: 10 v: LIFEBOOK E746
Mobo: FUJITSU model: FJNB293 v: M4 serial: <superuser required>
UEFI: FUJITSU // Insyde v: Version 1.35 date: 05/22/2019
ID-1: CMB1 charge: 51.5 Wh (95.0%) condition: 54.2/62.6 Wh (86.5%)
volts: 12.1 min: 10.8 model: Fujitsu CP700281-01 type: Li-ion
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1450 high: 2500 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 2500 3: 400
4: 2500 bogomips: 19999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Fujitsu driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Display: wayland server: Xwayland v: 22.1.3 compositor: sway v: 1.7
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: LG Display 0x04e3 built: 2015 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 scale: 1 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Fujitsu
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Ethernet I219-V vendor: Fujitsu driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-7:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 223.57 GiB used: 9.61 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: R022 scheme: GPT
ID-1: / raw-size: 97.85 GiB size: 97.85 GiB (100.00%) used: 9.57 GiB (9.8%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
(0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 125.41 GiB size: 125.41 GiB (100.00%) used: 42.5
MiB (0.0%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-6f1c95b6-3093-4b97-82bf-e3f7c074303d
ID-4: /var/log raw-size: 97.85 GiB size: 97.85 GiB (100.00%) used: 9.57
GiB (9.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 97.85 GiB size: 97.85 GiB (100.00%) used: 9.57
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 243 Uptime: 21m wakeups: 1 Memory: 7.67 GiB used: 1.14 GiB
(14.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1211 lib: 335 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.20
e[1;34mGaruda (2.6.6-1):e[0m
e[1;34m System install date:e[0m 2022-08-18
e[1;34m Last full system update:e[0m 2022-08-18 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
