Signature is... Invalid... again
inxi
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "pt_BR.UTF-8",
        LC_NAME = "pt_BR.UTF-8",
        LC_MONETARY = "pt_BR.UTF-8",
        LC_PAPER = "pt_BR.UTF-8",
        LC_IDENTIFICATION = "pt_BR.UTF-8",
        LC_TELEPHONE = "pt_BR.UTF-8",
        LC_MEASUREMENT = "pt_BR.UTF-8",
        LC_TIME = "pt_BR.UTF-8",
        LC_NUMERIC = "pt_BR.UTF-8",
        LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
  Kernel: 5.15.53-2-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
    root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff splash
  Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.5 info: cairo-dock, lxqt-panel
  Type: Desktop Mobo: INTEL model: HM65DESK serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 02/23/2019
  Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 built: 2010-12 process: Intel 32nm family: 6
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1521 high: 2175 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 2175 2: 1746 3: 901
    4: 1263 bogomips: 21552
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 515.57
    alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
    built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2
    speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1381 class-ID: 0300
  Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.12x11.81")
    s-diag: 487mm (19.18")
  Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49
    size: 708x398mm (27.87x15.67") diag: 812mm (31.98") modes: N/A
  OpenGL: renderer: NVIDIA GeForce GTX 750/PCIe/SSE2 v: 4.6.0 NVIDIA 515.57
    direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
  Sound Server-1: ALSA v: k5.15.53-2-lts running: yes
  Sound Server-3: PipeWire v: 0.3.55 running: yes
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 2.78 TiB used: 521.12 GiB (18.3%)
  ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
    physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
    rev: Sb10 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
    size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
  ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
    used: 97.92 GiB (17.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
  ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%)
    used: 240.8 MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
  ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
  ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
  ID-1: swap-1 type: zram size: 3.79 GiB used: 705.5 MiB (18.2%)
  System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
  Processes: 219 Uptime: 1h 1m wakeups: 0 Memory: 3.79 GiB
  used: 1.27 GiB (33.4%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1748
  pacman: 1736 lib: 540 flatpak: 12 Shell: Bash v: 5.1.16
  running-in: qterminal inxi: 3.3.19
Garuda (2.6.5-1):
  System install date:     2022-07-24
  Last full system update: 2022-07-13
Alright, the stuff I’m getting is this:
(147/147) checking keys in keyring                                              [----------------------------------------------] 100%
(147/147) checking package integrity                                            [----------------------------------------------] 100%
error: ananicy-rules-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/ananicy-rules-git-2.2.1.r293.ge26f09e-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: ant-dracula-kvantum-theme-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/ant-dracula-kvantum-theme-git-v3.0.r60.g58b8cf7-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ant-dracula-theme-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/ant-dracula-theme-git-3.0.r60.g58b8cf7-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Either with “paru -Su” or “pacman -Syu” or “update”. Same result, always.
I thought to myself “WAIT!! I KNOW THE ANSWER TO THIS PROBLEM, I’M NOT A COMPLETE NOOBIE” and went on with the following tutorial:
Did it work? Well,
No.
No it didn’t.
I tried the only other thing that popped up on my head: opened the G-Assistant (g for garuda ofc) and clicked on:
“Refresh Mirrorlist” and then
“Refresh Keyrings” and then
“System Update”
Next up on my list is seeing what y’all got up your sleeves cause mine are absolutely empty.
I’m not a noobie… that is, I’m not completely a noobie, but my skills end here sadly.
Any and all help and emotional support is greatly appreciated. C=
There seems to be a recurring issue with the Chaotic AUR builder that leads to a mismatch with -git packages. Usually it needs some manual intervention, but until that has been done you can ignore those packages for the update with e.g.
pacman -Syu --ignore ananicy-rules-git --ignore ant-dracula-kvantum-theme-git --ignore ant-dracula-theme-git
Oh... that's new to me xD
Alright then chief, ignored they will be.
Thank you so much for helping me out : 3
Should be fixed by now, sorry for the inconvenience :slight_smile:
Not at all. The problem continues with the Candid Icons pack. This guy
Nico Jensch (Chaotic-AUR) does not correct the length of the pack. It was 3 packages with error on Friday, now just one. Please, pay attention!
is dr460nf1r3. You can find him directly above your post.
Does it need an issue message in the AUR?
Thank you very much for the kind comment.
BTW, welcome in the Garuda Linux forum.
I just confirmed that it is in fact fixed. sudo pacman -Syu chaotic-aur/candy-icons-git
