So I installed the package signal-desktop-beta
from the Chaotic-aur
repo today, for Signal version 7.0.0-beta.1
It works fine except for the pinned icon in my taskbar. I’m posting this as it seems to be a problem with KDE pulling the .desktop file icon in while Signal is closed or in the systray. When Signal is actively on the screen, the icon shows correctly, as it does also in the application menu. It is just when I pin it to the taskbar, and close the window is when I get the unknown icon icon.
I tested this on both Wayland (current) and X11 environments, and the same problem persists. I tried install the AUR version signal-desktop-beta-bin
using both yay and paru to see if that would fix it (I had to edit the PKGBUILD to install the correct version since that package is flagged out of date, but it did end up installing the correct version), and it did not, the problem persisted. I tried to symlink both the AUR package and Chaotic-aur package versions (only one was installed at a time), and still did not have success. I’m not sure if KDE isn’t pulling the icon as it should be, and as I would expect it to, or if there is a bug in the task manager that I need to report upstream. Hopefully you all can think of something I perhaps missed…
See screenshots below my inxi.
Garuda-inxi:
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3373435f-7258-4a74-86df-c8de3e605fd3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <filter>
uuid: 4dcbff1a-cb18-cd47-bc11-aa5d4f09a3e4 UEFI: American Megatrends LLC.
v: FX516PM.330 date: 05/15/2023
ID-1: BAT0 charge: 57.4 Wh (97.0%) condition: 59.2/76.0 Wh (77.9%)
power: 39.2 W volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 375
Info: model: 11th Gen Intel Core i7-11370H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xB4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 859 high: 1300 min/max: 400/4800 base/boost: 3300/4800
ext-clock: 100 MHz cores: 1: 1095 2: 400 3: 772 4: 551 5: 862 6: 1048
7: 1300 8: 851 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-3,DP-5 off: eDP-1 empty: DP-1, DP-2, DP-4, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2024-02;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 ports: active: none empty: HDMI-A-2 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Creative Live! Cam Sync 1080p driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:5
chip-ID: 041e:409f class-ID: 0102 serial: <filter>
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :1
s-diag: 1245mm (49.01")
Monitor-1: DP-3 pos: right res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
Monitor-2: DP-5 pos: primary,left res: 2560x1440 hz: 144 dpi: 93
size: 700x390mm (27.56x15.35") diag: 801mm (31.55") modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.0.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.1-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
Device-3: Logitech G535 Wireless Gaming Headset
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2 chip-ID: 046d:0ac4
class-ID: 0a00
Device-4: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
lanes: 1 mode: 1.1 bus-ID: 5-2.1.1.2:9 chip-ID: 17ef:3083 class-ID: 0300
Device-5: Creative Live! Cam Sync 1080p driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
bus-ID: 0000:2e:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Lenovo ThinkPad TBT 3 Dock driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.1.2:4
chip-ID: 17ef:3082 class-ID: 0000 serial: <filter>
IF: enp4s0u2u1u2 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 19.05 GiB (1.4%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 163d 7h cycles: 1,078
read-units: 38,715,488 [19.8 TB] written-units: 31,866,679 [16.3 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
fw-rev: FXM7201Q temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 115d 14h cycles: 2,444
read-units: 38,614,090 [19.7 TB] written-units: 62,377,850 [31.9 TB]
ID-1: / raw-size: 123.41 GiB size: 123.41 GiB (100.00%)
used: 19.05 GiB (15.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p5
maj-min: 259:10
ID-2: /boot/efi raw-size: 750 MiB size: 748.5 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p4
maj-min: 259:9
ID-3: /home raw-size: 123.41 GiB size: 123.41 GiB (100.00%)
maj-min: 259:10
ID-4: /var/log raw-size: 123.41 GiB size: 123.41 GiB (100.00%)
maj-min: 259:10
ID-5: /var/tmp raw-size: 123.41 GiB size: 123.41 GiB (100.00%)
maj-min: 259:10
ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2200
Memory: total: 16 GiB available: 15.32 GiB used: 2.88 GiB (18.8%)
igpu: 64 MiB
Processes: 270 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1592 libs: 430 tools: octopi,pacseek,paru
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-20
Last full system update: 2024-02-20
Windows dual boot: Yes
![image](https://forum.garudalinux.org/uploads/default/original/3X/0/7/07cfc74ea63d25658ef58598b7d6577262519ffb.png)
