Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7f0ae556-4168-4eec-b258-895af093d585 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 info: latte-dock
Type: Laptop System: Sony product: VPCEB3TFX v: C606UX3M
Mobo: Sony model: VAIO serial: <superuser required>
BIOS: American Megatrends v: R1140Y8 date: 10/06/2010
ID-1: BAT0 charge: 4.8 Wh (100.0%) condition: 4.8/47.5 Wh (10.0%) volts: N/A
min: 121.6 model: Sony Corp. type: Li-ion serial: N/A status: full
Info: model: Intel Core i3 M 350 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 931 high: 933 min/max: 933/2266 scaling:
driver: acpi-cpufreq governor: performance cores: 1: 931 2: 931 3: 931
4: 933 bogomips: 18087
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel Core Processor Integrated Graphics vendor: Sony driver: i915
v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Monitor-1: LVDS-1 res: 1920x1080 hz: 60 size: N/A modes: 1920x1080
API: OpenGL v: 2.1 Mesa 23.0.2 renderer: Mesa Intel HD Graphics (ILK)
direct-render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn
T77H126.00 802.11bgn driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:002b class-ID: 0280
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Sony driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: b000 bus-ID: 04:00.0 chip-ID: 11ab:4381 class-ID: 0200
Local Storage: total: 521.66 GiB used: 362.64 GiB (69.5%)
ID-1: /dev/sda maj-min: 8:0 model: GAM X 240G size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
rev: 5A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HM321HI
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0002 scheme: MBR
ID-1: / raw-size: 62.96 GiB size: 62.96 GiB (100.00%)
used: 39.72 GiB (63.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw-size: 62.96 GiB size: 62.96 GiB (100.00%)
ID-3: /var/log raw-size: 62.96 GiB size: 62.96 GiB (100.00%)
ID-4: /var/tmp raw-size: 62.96 GiB size: 62.96 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.5 GiB used: 913.2 MiB (25.5%)
System Temperatures: cpu: 71.0 C mobo: N/A
Processes: 230 Uptime: 1h 38m wakeups: 1 Memory: 3.5 GiB
used: 2.5 GiB (71.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: dpkg pkgs: 0 pm: pacman
pkgs: 2011 libs: 555 tools: octopi,pamac,paru pm: rpm pkgs: 0 Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2022-10-18
Last full system update: 2023-04-15
Failed units: jellyfin.service
Hi, I'm new to Garuda Linux, and Linux in general.
I love applications without titlebar and frame, but I don't like to use alt+f3 every time and then selected More Actions and then finally click on Move or resize button. This is the only way I've been able to move/resize some applications on the screen.
I tried to look for how I could create shortcuts that could do this but failed. Is there a way to create a shortcut that I can use to move and resize applications around quickly that have more titlebar or frame?
I'd like to add image to make it more clear, but I can't do it as I'm a new user.
