I have been used to open any folder, e.g., /home/usr/my_folder, and press shit+F4, fish terminal would appear immediately as if I had pressed ctrl+alt+t and typed cd /home/usr/my_folder and this used to save me a lot of time.
Since I used pacman -Syu the command shift+F4 seems to be triggered, it seems like the OS is trying to open fish terminal, but it does not open.
At this screenshot you can see what happens. This icon close to the pointer appears when I press shift+F4, but fish does not open.
But if I right click on the folder, click on administrative actions and then click on open this folder on terminal, it works!
Very strange, I reinstalled dolphin and fish, but the issue persists.
ctrl+alt+t still works as expected, but shift+F4 on dolphin does not and "opening folder on terminal as admin" works
╰─λ pacman -Ss kinit
core/mkinitcpio 31-2 [instalado]
Modular initramfs image creation utility
core/mkinitcpio-busybox 1.34.1-1 [instalado]
Base initramfs tools
core/mkinitcpio-nfs-utils 0.3-7 [instalado]
ipconfig and nfsmount tools for NFS root support in mkinitcpio
extra/hwdetect 2021.10-1
Hardware detection script with loading modules and mkinitcpio.conf
extra/kinit 5.89.0-1 (kf5) [instalado]
Process launcher to speed up launching KDE applications
extra/mkinitcpio-archiso 60-1
Initcpio scripts used by archiso
community/mkinitcpio-dropbear 0.0.3-6
Archlinux mkinitcpio hook to install and enable the dropbear daemon in early userspace
community/mkinitcpio-netconf 0.0.5-2
Archlinux mkinitcpio hook for configuring early userspace networking
community/mkinitcpio-systemd-tool 37-1 [instalado]
Provisioning tool for systemd in initramfs (systemd-tool)
community/mkinitcpio-tinyssh 0.0.4-4
Archlinux mkinitcpio hook to install and enable the tinyssh daemon in early userspace
community/mkinitcpio-utils 0.0.4-1
Collection of Archlinux mkinitcpio utilities performing various tasks
chaotic-aur/kinit-git 5.90.0_r426.gb41502f-1
chaotic-aur/mkinitcpio-firmware 1.1.1-1
Optional firmware for the default linux kernel to get rid of the annoying 'WARNING: Possibly missing firmware for
module:' messages
chaotic-aur/mkinitcpio-git 31.r2.ga72cc79-1
Modular initramfs image creation utility - git checkout
chaotic-aur/mkinitcpio-openswap 0.1.0-3 [instalado]
mkinitcpio hook to open swap at boot time
Not completely sure, I would say 85% certainty
Hundreds of things were updated and it already had caused me a lot of trouble, I would not like to mess up with it again >.<
Some time passed since I've done it so I would not like to restore to that old state again, but yes, since that day shift+F4 is not working as expected
