Wheres is shells settings on Garuda?
The system says it uses bash:
$ echo $SHELL
/bin/bash
$ cat /etc/passwd | grep $USER | cut -d: -f7
/bin/bash
But the behavior is like fish:
$ abc=123
fish: Unsupported use of '='. In fish, please use 'set abc 123'.
On ~/.bashrc
: echo "abc"
Don't show "abc" on new shell.
I have very specifics configs to my shells, so I need to understand how the system is working to make them.
Looks like the default shell is bash but fish is being initialized somewhere. Please, where is these settings?
$ garuda-inxi
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@boot/vmlinuz-linux-zen
root=UUID=e1adc2d5-7b7d-4266-8e23-555c7e26c364 rw
[email protected] quiet
cryptdevice=UUID=7b1ced1a-3ab8-4284-9652-bdd8a1f83892:luks-7b1ced1a-3ab8-4284-9652-bdd8a1f83892
root=/dev/mapper/luks-7b1ced1a-3ab8-4284-9652-bdd8a1f83892 quiet splash
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 5502 v: N/A
Mobo: Dell model: 0YWFX8 v: A00 serial: <superuser required> UEFI: Dell
v: 1.7.1 date: 08/06/2021
ID-1: BAT0 charge: 46.0 Wh (100.0%) condition: 46.0/53.0 Wh (86.8%)
volts: 16.6 min: 15.0 model: BYD DELL TXD0316 type: Unknown serial: <filter>
status: full
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1700 min/max: 400/4700 scaling: driver: intel_pstate
governor: performance cores: 1: 1700 2: 1700 3: 1700 4: 1700 5: 1700 6: 1700
7: 1700 8: 1700 bogomips: 27033
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce MX350] vendor: Dell driver: nouveau
v: kernel non-free: 525.xx+ status: current (as of 2023-02) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 bus-ID: 0000:2b:00.0
chip-ID: 10de:1c94 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:671b class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: LG Display 0x05f2 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 131.55 GiB (27.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 92103061 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 350.57 GiB size: 350.57 GiB (100.00%)
used: 131.55 GiB (37.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-7b1ced1a-3ab8-4284-9652-bdd8a1f83892
ID-2: /boot raw-size: 350.57 GiB size: 350.57 GiB (100.00%)
ID-3: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 380 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /home raw-size: 350.57 GiB size: 350.57 GiB (100.00%)
ID-5: /var/log raw-size: 350.57 GiB size: 350.57 GiB (100.00%)
ID-6: /var/tmp raw-size: 350.57 GiB size: 350.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 22.8 MiB (0.1%)
System Temperatures: cpu: 74.0 C mobo: 68.0 C gpu: nouveau temp: 68.0 C
Fan Speeds (RPM): cpu: 5400
Processes: 305 Uptime: 3d 3h 26m wakeups: 28695 Memory: 15.36 GiB
used: 7.47 GiB (48.6%) Init: systemd v: 253 default: graphical
pkgs: 1933 libs: 522 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-18
Last full system update: 2023-03-07 ↻
Is partially upgraded: Yes
