Sharing pc with someone else on the same network
Hey guys, first time posting, i have read the template but i don’t really know how to explain my problem really well.
So the issue is:
I’m trying to share the “power” of my PC so that my sister who as a potato pc can actually play her favorite games using the power from mine.(not very demanding ones Genshin Impact/etc)
Do you guys think there’s a way that i can setup a VM or share a user account to achieve that?
Keep in mind shes not a nerd, and the thing from the side of my pc shouldn’t need her input to the day to day use.
Sorry for the messy explanation.
And thanks for any help/opinion you can provide.
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=fec233c0-3f73-4599-a920-c6900a07b2dc rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: Z370 Killer SLI
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P4.30C
date: 04/01/2021
Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
desc: 1x9 MiB
Speed (MHz): avg: 900 min/max: 800/4300:4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900
bogomips: 43200
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: ASUSTeK driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-1,DP-2 empty: DP-3,HDMI-A-1,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2486 class-ID: 0300
Device-2: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-8.1.1.1:5
chip-ID: 28de:2400 class-ID: 0e02 serial: <filter>
s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 dpi: 92 size: 531x298mm (20.91x11.73")
diag: 609mm (23.97") modes: N/A
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2486
surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
Device-3: Razer USA Barracuda X 2.4
lanes: 1 mode: 1.1 bus-ID: 1-11:2 chip-ID: 1532:0552 class-ID: 0301
Device-4: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13.1.1.3.2:14
chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-5: Valve VR Radio & HMD Mic
lanes: 1 mode: 1.1 bus-ID: 1-13.1.1.3.3:15 chip-ID: 28de:2102
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
Local Storage: total: 2.05 TiB used: 962.05 GiB (45.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRS1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 15.8 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT250MX500SSD1
tech: SSD serial: <filter> fw-rev: 010 scheme: GPT
used: 126.62 GiB (13.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.55 GiB used: 2 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 25 C
Processes: 313 Uptime: 1h 3m wakeups: 0 Memory: total: 16 GiB
available: 15.55 GiB used: 5.51 GiB (35.5%) Init: systemd v: 254
pm: pacman pkgs: 1786 libs: 522 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-24
Last full system update: 2023-11-30
I think you have given answere to your own question :wink:
You can alternately install a “Guest” account for her use. If she’s not the most knowledgeable computer user there’s less risk of her messing things up with a guest account.
Heh I have done that in the past, but the idia was that she could access it from her one computer while I’m “asleep, or at work” without going into my room or my computer(fisically).
I’m currently looking at the VM way as I have done that in the past when I used windows and for some other reason.
I was just wondering if there are a better way you guys might know or could help with your knowledge.
You can dualboot other than that, as you are thinking of VM so in VM there might be some less performance than usual so you can do this :wink:
