Sorry if I post in wrong place as I am beginner I installed garuda-hyprland after implementing the setup by mod+shift+g , after that at top of screen showing config error something like
/home/username/.config/hypr/settings/blur_system.conf
shadow:enable doesn’t exist more.
3 lines like this of same folder. How I fix it, please help
Ankur
9 November 2024 15:42
2
please give output of garuda-inxi
from terminal as mentioned in template,
disable G-Hyprland again by the same keybinding , i.e. Mod+Shift+g
then update your system with
upd
then , after a restart you can enable it again and it won’t show errors
The errors are due to recent update in Hyprland upstream itself
for which fixes are already addressed . if you want to know about the changes done in garuda hyprland then you can see the repo :
And :
Thanks it resolved my issue
system
Closed
12 November 2024 03:32
4
