System locks up/crashes when starting most games. Optimus Laptop.
Thinking it was something i've done, and made worse, by tinkering and fumbling, i've done another fresh install of Garuda, and completely wiped all my Steam folders, starting from a clean system.
Started by installing Dota 2 for testing, as it allows specifically selecting Vulkan/GL, and is Linux native, to rule out Proton issues. (any smaller games for this?)
First run, the game freezes at Valve logo (Audio continues). SysRq + R, E will get me back to login screen (How do I re-start the wifi network after login?)
After reboot, and starting Dota 2 again, the game loads and I can access settings, and see that Vulkan is activated. I went to start a bot match, but the game had already frozen (mouse still working, cannot alt+tab or alt+f4)
For testing, I installed Ubuntu 22.10 on another partition, and don't have this issue. The nvidia-settings on Ubuntu also shows me settings for prime-offloading, Garuda does not.
Really stuck here! Thanks guys.
```text
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6ca60521-1e7b-42e6-baa3-258a2e6c5c75
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GE72VR 6RF v: REV:1.0 serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: Micro-Star model: MS-179B v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E179BIMS.10E date: 01/16/2018
ID-1: BAT1 charge: 40.6 Wh (91.0%) condition: 44.6/53.4 Wh (83.5%) volts: 12.0 min: 10.9
model: MSI Corp. MS-179B type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S gen: core 6 level: v3
note: check built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3129 high: 3199 min/max: 800/3500 scaling: driver: intel_pstate
governor: performance cores: 1: 3104 2: 3101 3: 3101 4: 3197 5: 3101 6: 3132 7: 3100 8: 3199
bogomips: 41599
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Micro-Star MSI driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x0469 built: 2014 res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 530 (SKL GT2)
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: g
en: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Micro-Star MSI driver: alx
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e0a1
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 4.55 TiB used: 1005.2 GiB (21.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8 size: 931.51 GiB
rev: P4CR324 temp: 56.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB size: 3.64 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 31.65 GiB (10.8%) fs: btrfs
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%) used: 133.3 MiB (13.3%) fs: vfat
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 31.65 GiB (10.8%) fs: btrfs
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 31.65 GiB (10.8%)
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 31.65 GiB (10.8%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 4.2 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 55.0 C pch: 62.5 C mobo: N/A
Processes: 281 Uptime: 11m wakeups: 1 Memory: 15.5 GiB used: 4.07 GiB (26.3%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pm: pacman pkgs: 2085 libs: 571 tools: octopi,paru Client: shell wrapper v: 5.1.16-release
inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-03
Last full system update: 2022-12-03
