I see the autostart option in the KDE settings but I want to delay one of the apps by about a minute. How would I do that? I know on Windows you have Task Scheduler that allows you to setup bootup time parameters. Is there any similar functionality on KDE?
Kernel: 6.10.0-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=4b50f2bb-29e3-46db-902d-6f9025f83b73 rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
serial: <filter> part-nu: SKU uuid: dccab955-4204-f11a-eeb3-04421af1eeb2
UEFI: American Megatrends v: 4702 date: 10/20/2023
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4950 boost: enabled
base/boost: 3700/4950 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3700 20: 3700
21: 3700 22: 3700 23: 3700 24: 3700 bogomips: 177608
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 0b:00.0
chip-ID: 10de:2684 class-ID: 0300
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
Screen-1: 0 s-res: 5120x1440 s-dpi: 107 s-size: 1216x342mm (47.87x13.46")
s-diag: 1263mm (49.73")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: left model: VG27A
serial: <filter> built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-2 note: disabled pos: primary,right model: VG27AQL1A
serial: <filter> built: 2020 res: 2560x1440 dpi: 65024 gamma: 1.2
size: 1x1mm (0.04x0.04") diag: 685mm (27") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled
model: LG (GoldStar) TV SSCR2 serial: <filter> built: 2021 res: 2560x1440
dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 555.58.02
device-ID: 10de:2684 surfaces: xcb,xlib
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:22ba class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Schiit Audio Modi 3+ driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:4 chip-ID: 30be:1014
class-ID: 0102
API: ALSA v: k6.10.0-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
Local Storage: total: 9.18 TiB used: 3.45 TiB (37.6%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 51.9 C
SMART: yes health: PASSED on: 139d 6h cycles: 955
read-units: 129,175,224 [66.1 TB] written-units: 18,500,697 [9.47 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
SMART: yes health: PASSED on: 350d 2h cycles: 1,511
read-units: 136,892,814 [70.0 TB] written-units: 91,129,493 [46.6 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 family: based SSDs
size: 1.86 TiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 7A temp: 23 C
SMART: yes state: enabled health: PASSED on: 1y 177d 23h cycles: 1696
read: 19.35 TiB written: 25.23 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800
family: based SSDs size: 1.86 TiB block-size: physical: 512 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 7A temp: 17 C
SMART: yes state: enabled health: PASSED on: 332d 2h cycles: 941
read: 12.39 TiB written: 19.85 TiB
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0001 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 9841h+46m+59.521s
cycles: 1654 read: 23.6 TiB written: 8.26 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.35 TiB (74.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:5
used: 27.4 MiB (9.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:4
used: 1.35 TiB (74.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:5
maj-min: 259:5
maj-min: 259:5
ID-1: swap-1 type: zram size: 62.7 GiB used: 447 MiB (0.7%) priority: 100
System Temperatures: cpu: 47.0 C mobo: 34.0 C gpu: nvidia temp: 46 C
Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 0%
Memory: total: 64 GiB available: 62.7 GiB used: 7.71 GiB (12.3%)
Processes: 563 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2002 libs: 554 tools: octopi,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 0 Compilers: clang: 18.1.8
gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-06-08
Last full system update: 2024-07-24
Windows dual boot: Yes
