Hey all. So I'm installing Garuda xfce on a lappie, fresh install, first login, met with auto update from setup asst. That update failed with a different problem, fixed that and initial update succeeded. Go into setup asst. pick all the packages I wanted, hit go, and it errors with this (terminal output below). I assume this is just a problem of keys/certificates signatures being expired, and someone just needs to kick Nico in the butt so they can refresh their certs/keys, but I'm not positive. Any help would be appreciated. I tried "sudo pacman -Syyuu" which was suggested in a thread, cleared package caches, and refreshed mirrors. None of that helped. TIA
â•─melanhead@squarepants in ~ took 14ms
╰─λ garuda-inxi
Kernel: 6.1.31-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6b731818-4136-4a58-98bd-239e40d805ac rw rootflags=subvol=@
resume=UUID=fa3f2f7e-67d4-468d-a5b1-3f3a8614e66e loglevel=3 ibt=off
Type: Laptop System: HP product: HP Laptop 14-dk0xxx v: N/A
Mobo: HP model: 85E0 v: 84.50 serial: <superuser required> UEFI: AMI
v: F.64 date: 09/22/2021
ID-1: BAT0 charge: 38.5 Wh (100.0%) condition: 38.5/38.5 Wh (100.0%)
volts: 12.9 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1700 high: 2600 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1400 4: 2600 bogomips: 20770
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 53.0 C
Device-2: IMC Networks HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:56c9
compositor: xfwm v: 4.18.0 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14e3 built: 2017
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon Vega 3 Graphics
(raven2 LLVM 15.0.7 DRM 3.49 6.1.31-1-lts) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.1.31-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 0bda:b00a
Local Storage: total: 119.24 GiB used: 19.06 GiB (16.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN128HAHQ-000H1
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4H3Q scheme: GPT
ID-1: / raw-size: 111.8 GiB size: 111.8 GiB (100.00%)
used: 19.06 GiB (17.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 111.8 GiB size: 111.8 GiB (100.00%)
ID-4: /var/log raw-size: 111.8 GiB size: 111.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.8 GiB size: 111.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.25 GiB used: 605.5 MiB (18.2%)
ID-2: swap-2 type: partition size: 7.15 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.8 C mobo: N/A gpu: amdgpu temp: 52.0 C
Processes: 248 Uptime: 1h 3m wakeups: 1 Memory: available: 3.25 GiB
used: 1.61 GiB (49.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1922 libs: 519 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27
System install date: 2023-05-29
Last full system update: 2023-05-31 ↻
It's actually doing this for Black Arch repo, Virtualbox, Wine and a few others. I just ran it through with Black Arch to show the error. Also, it doesn't matter whether I hit y/n at the bottom. It fails either way...
Installing packages..
resolving dependencies...
Packages (4) blackarch-keyring-20180925-5 blackarch-menus-10.5244eea-3
blackarch-mirrorlist-20230508-1 garuda-blackarch-1.1.0-1
Total Download Size: 0.05 MiB
Total Installed Size: 0.12 MiB
Net Upgrade Size: 0.08 MiB
:: Retrieving packages...
garuda-blackarch... 53.1 KiB 175 KiB/s 00:00 [----------------------] 100%
(4/4) checking keys in keyring [----------------------] 100%
(4/4) checking package integrity [----------------------] 100%
error: garuda-blackarch: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/garuda-blackarch-1.1.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Error! Press enter to return to setup assistant.
$ garuda-update remote keyring
Will likely fix this, it updates all the keyrings.
Probably best to reboot after the update.
Hey thanks for responding. I tried, rebooted, and same issue still.
libvirt-1:9.3.0-... 8.3 MiB 5.06 MiB/s 00:02 [----------------------] 100%
edk2-ovmf-202302... 15.3 MiB 5.34 MiB/s 00:03 [----------------------] 100%
virtualbox-sdk-7... 7.5 MiB 4.11 MiB/s 00:02 [----------------------] 100%
qemu-system-x86-... 5.8 MiB 3.97 MiB/s 00:01 [----------------------] 100%
virtualbox-guest... 37.1 MiB 6.40 MiB/s 00:06 [----------------------] 100%
qt5-tools-5.15.9... 5.3 MiB 2.03 MiB/s 00:03 [----------------------] 100%
luminancehdr-2.6... 5.0 MiB 2.36 MiB/s 00:02 [----------------------] 100%
nextcloud-client... 4.0 MiB 3.61 MiB/s 00:01 [----------------------] 100%
virtualbox-ext-o... 2.5 MiB 1972 KiB/s 00:01 [----------------------] 100%
qemu-img-8.0.0-1... 2.0 MiB 3.19 MiB/s 00:01 [----------------------] 100%
qemu-common-8.0.... 1975.2 KiB 2.80 MiB/s 00:01 [----------------------] 100%
openssl-1.1-1.1.... 1801.5 KiB 3.24 MiB/s 00:01 [----------------------] 100%
dragon-23.04.1-1... 1735.9 KiB 3.05 MiB/s 00:01 [----------------------] 100%
virtualbox-7.0.8... 56.3 MiB 6.46 MiB/s 00:09 [----------------------] 100%
capstone-4.0.2-7... 1238.7 KiB 5.04 MiB/s 00:00 [----------------------] 100%
kparts-5.106.0-1... 1037.9 KiB 3.62 MiB/s 00:00 [----------------------] 100%
gnome-boxes-44.2... 936.4 KiB 3.30 MiB/s 00:00 [----------------------] 100%
cdrtools-3.02a09... 901.0 KiB 1889 KiB/s 00:00 [----------------------] 100%
wolfssl-5.6.0-1-... 828.6 KiB 3.37 MiB/s 00:00 [----------------------] 100%
octopi-0.14.0-2-... 1474.0 KiB 1776 KiB/s 00:01 [----------------------] 100%
virtiofsd-1.6.1-... 774.2 KiB 2.18 MiB/s 00:00 [----------------------] 100%
virtualbox-host-... 761.5 KiB 3.72 MiB/s 00:00 [----------------------] 100%
cfitsio-1:4.2.0-... 574.2 KiB 3.00 MiB/s 00:00 [----------------------] 100%
spice-gtk-0.42-3... 511.2 KiB 2.20 MiB/s 00:00 [----------------------] 100%
qemu-tools-8.0.0... 425.4 KiB 2.01 MiB/s 00:00 [----------------------] 100%
libtpms-0.9.6-1-... 419.2 KiB 2.66 MiB/s 00:00 [----------------------] 100%
multipath-tools-... 352.3 KiB 3.82 MiB/s 00:00 [----------------------] 100%
spice-0.15.2-1-x... 343.8 KiB 3.14 MiB/s 00:00 [----------------------] 100%
ccfits-2.6-2-x86_64 336.8 KiB 1574 KiB/s 00:00 [----------------------] 100%
qemu-pr-helper-8... 334.4 KiB 2.04 MiB/s 00:00 [----------------------] 100%
libvirt-glib-4.0... 298.9 KiB 2.43 MiB/s 00:00 [----------------------] 100%
libosinfo-1.10.0... 277.2 KiB 1296 KiB/s 00:00 [----------------------] 100%
qemu-vhost-user-... 241.5 KiB 2.84 MiB/s 00:00 [----------------------] 100%
virglrenderer-0.... 224.0 KiB 1806 KiB/s 00:00 [----------------------] 100%
libvncserver-0.9... 231.1 KiB 1179 KiB/s 00:00 [----------------------] 100%
ttf-wps-fonts-1.... 247.6 KiB 979 KiB/s 00:00 [----------------------] 100%
qtermwidget-1.3.... 216.9 KiB 1382 KiB/s 00:00 [----------------------] 100%
vde2-2.3.3-3-x86_64 211.3 KiB 2.58 MiB/s 00:00 [----------------------] 100%
osinfo-db-202305... 206.8 KiB 2.08 MiB/s 00:00 [----------------------] 100%
seabios-1.16.2-1-any 174.1 KiB 2.43 MiB/s 00:00 [----------------------] 100%
dtc-1.7.0-4-x86_64 151.1 KiB 1820 KiB/s 00:00 [----------------------] 100%
sdl12-compat-1.2... 129.3 KiB 1333 KiB/s 00:00 [----------------------] 100%
virtualbox-ext-v... 86.9 KiB 1242 KiB/s 00:00 [----------------------] 100%
qt5-websockets-5... 80.3 KiB 1085 KiB/s 00:00 [----------------------] 100%
sdl2_image-2.6.3... 66.1 KiB 472 KiB/s 00:00 [----------------------] 100%
phodav-3.0-2-x86_64 65.7 KiB 450 KiB/s 00:00 [----------------------] 100%
qtkeychain-qt5-0... 58.5 KiB 450 KiB/s 00:00 [----------------------] 100%
qemu-ui-dbus-8.0... 58.1 KiB 354 KiB/s 00:00 [----------------------] 100%
usbredir-0.13.0-... 43.3 KiB 562 KiB/s 00:00 [----------------------] 100%
garuda-blackarch... 53.1 KiB 290 KiB/s 00:00 [----------------------] 100%
libcacard-2.7.0-... 40.3 KiB 746 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 35.0 KiB 625 KiB/s 00:00 [----------------------] 100%
qemu-ui-gtk-8.0.... 27.9 KiB 399 KiB/s 00:00 [----------------------] 100%
wps-office-mime-... 31.8 KiB 134 KiB/s 00:00 [----------------------] 100%
pkgfile-21-2-x86_64 24.8 KiB 310 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 24.6 KiB 493 KiB/s 00:00 [----------------------] 100%
qemu-hw-usb-redi... 24.4 KiB 609 KiB/s 00:00 [----------------------] 100%
qemu-ui-spice-co... 24.3 KiB 517 KiB/s 00:00 [----------------------] 100%
xorg-mkfontscale... 23.1 KiB 384 KiB/s 00:00 [----------------------] 100%
qemu-hw-usb-host... 22.4 KiB 373 KiB/s 00:00 [----------------------] 100%
spice-protocol-0... 21.3 KiB 319 KiB/s 00:00 [----------------------] 100%
qemu-ui-sdl-8.0.... 16.9 KiB 368 KiB/s 00:00 [----------------------] 100%
qemu-block-ssh-8... 16.9 KiB 296 KiB/s 00:00 [----------------------] 100%
liblzf-3.6-4-x86_64 16.8 KiB 280 KiB/s 00:00 [----------------------] 100%
qemu-system-x86-... 15.5 KiB 353 KiB/s 00:00 [----------------------] 100%
qemu-ui-curses-8... 13.8 KiB 261 KiB/s 00:00 [----------------------] 100%
alpm_octopi_util... 19.3 KiB 98.7 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 13.7 KiB 218 KiB/s 00:00 [----------------------] 100%
qemu-hw-usb-smar... 13.5 KiB 270 KiB/s 00:00 [----------------------] 100%
qemu-ui-opengl-8... 13.4 KiB 286 KiB/s 00:00 [----------------------] 100%
qemu-block-curl-... 13.3 KiB 251 KiB/s 00:00 [----------------------] 100%
qemu-block-nfs-8... 12.7 KiB 255 KiB/s 00:00 [----------------------] 100%
qemu-audio-alsa-... 11.9 KiB 199 KiB/s 00:00 [----------------------] 100%
qemu-audio-dbus-... 11.4 KiB 228 KiB/s 00:00 [----------------------] 100%
qemu-audio-pa-8.... 10.9 KiB 172 KiB/s 00:00 [----------------------] 100%
qemu-audio-oss-8... 10.0 KiB 184 KiB/s 00:00 [----------------------] 100%
qemu-chardev-spi... 9.6 KiB 96.2 KiB/s 00:00 [----------------------] 100%
qemu-audio-jack-... 9.5 KiB 258 KiB/s 00:00 [----------------------] 100%
qemu-audio-sdl-8... 8.5 KiB 198 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 8.1 KiB 142 KiB/s 00:00 [----------------------] 100%
qemu-ui-spice-ap... 8.0 KiB 151 KiB/s 00:00 [----------------------] 100%
qemu-audio-spice... 7.6 KiB 143 KiB/s 00:00 [----------------------] 100%
qemu-ui-egl-head... 7.4 KiB 106 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 6.7 KiB 92.3 KiB/s 00:00 [----------------------] 100%
qemu-hw-s390x-vi... 6.3 KiB 100 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 6.2 KiB 96.2 KiB/s 00:00 [----------------------] 100%
qemu-block-dmg-8... 6.0 KiB 63.0 KiB/s 00:00 [----------------------] 100%
qemu-hw-display-... 5.9 KiB 66.0 KiB/s 00:00 [----------------------] 100%
qemu-desktop-8.0... 4.8 KiB 88.4 KiB/s 00:00 [----------------------] 100%
virtualbox-meta-... 3.1 KiB 13.7 KiB/s 00:00 [----------------------] 100%
blackarch-menus-... 9.4 KiB 7.61 KiB/s 00:01 [----------------------] 100%
blackarch-mirror... 3.0 KiB 3.52 KiB/s 00:01 [----------------------] 100%
wps-office-11.1.... 437.2 MiB 19.0 MiB/s 00:23 [----------------------] 100%
Total (93/93) 606.2 MiB 25.9 MiB/s 00:23 [----------------------] 100%
(94/94) checking keys in keyring [----------------------] 100%
(94/94) checking package integrity [----------------------] 100%
error: virtualbox-meta: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/virtualbox-meta-2-3-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
I'll be looking into it as soon as I can.
That'd be amazing, mate. I've also tried a few other things, since posting, to no avail. Here's what I've tried...
First, here's a list of the packages that are failing for me, either through the initial setup asst, or from the "Games" tab in the "Garuda Gamer" section of the "Garuda Welcome" package.
Winetricks, Protontricks, Wine, Xone-dkms, Virtualbox, Black Arch repo...these are just the ones that I'm trying to get, there may be more.
So I found this... [Issues with “signature is marginal trust”, "signature is unknown trust", or “invalid or corrupted package” ] and tried a few of these first off I tried
sudo pacman -Sy archlinux-keyring chaotic-keyring blackarch-keyring
sudo pacman -Syu
sudo pacman-key --refresh-keys
sudo pacman-key --refresh-keys --keyserver hkps://keyserver.ubuntu.com
None of this worked, so I tried to clear out the pacman keyring and start fresh with...
sudo rm -fr /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate archlinux chaotic
sudo pacman -Syy archlinux-keyring chaotic-keyring blackarch-keyring
sudo pacman -Syu
After borking it the first time with poor spelling, I went through it again, and successfully cleared and refreshed the keyring, but I'm still at the same problem.Thanks so much for responding.
The last one is just a typo, should be garuda-inxi.
Hehe...so it was. Thank you! Getting old sucks! Fixed in OP
SkullBunny46290:
Winetricks, Protontricks, Wine, Xone-dkms, Virtualbox, Black Arch repo…these are just the ones that I’m trying to get, there may be more.
I could confirm xone-dkms, fixed. The rest, also virtualbox-meta and garuda-blackarch installed flawlessly for me, so it can’t be an issue with package signatures.
Would someone else be able to test whether these install?
SkullBunny46290:
I think the exact outputs would be useful, unless they are the same as shown above.
Hi Nico, at least for garuda-blackarch I can confirm the problem:
╰─λ sudo pacman -S garuda-blackarch
[sudo] password for filippo:
Packages (1) garuda-blackarch-1.1.0-1
Total Download Size: 0,05 MiB
Total Installed Size: 0,07 MiB
garuda-blackarch-1.1.0-1-any 53,1 KiB 185 KiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
On the contrary, I already have virtualbox-meta and wine-meta installed from Garuda (so chaotic-aur in the end) and they can be reinstalled correctly.
Thanks for double-checking this for me. garuda-blackarch should also be fixed by now.
Yeah, they were all the same as above. Just got home and retried, and everything installed flawlessly. IDK what you did, Nico, but you’re a genius, mate! Many thanks and salutations.
system
Closed
4 June 2023 01:03
12
